tonneaucovered.com
Old 12-25-2010, 12:57 AM
MAXX25's Avatar
MAXX25 MAXX25 is offline
Vehicle: 2013 Dodge Ram
Trim Level: Laramie 4x4
Rep:12
MAXX25 is on a distinguished road
Default Bilstein 5100 Shocks
I'm getting some Bilstein 5100 Shocks for the front only what height should i set the shocks at. I was thinking 2.1 I just want it level thanks.
It is what it is !!!
Old 12-25-2010, 01:00 AM
Rep:1625
Set them at the highest possible setting, and you'll be fine.
Old 12-25-2010, 01:01 AM
Measure a bit first but highest setting usually works the best.
Old 12-25-2010, 01:05 AM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
I have mine set at second highest setting 2.1" the front is still 1/4" lower but thats ok because the rear will sag when I hook up my boat trailer and I do nor want the nose high while towing! I have a thread in the suspension lift section if you want to see pics http://www.ramforumz.com/showthread.php?t=67017
Old 12-25-2010, 04:11 AM
MAXX25's Avatar
Rep:12
The highest setting is like 2.8 I just thought that would be alittle to high. I dont do alot of hauling, so maybe the highest setting but i will measure first.
Old 12-26-2010, 05:39 PM
onequicktang onequicktang is offline
Vehicle: 2010 RAM
onequicktang is on a distinguished road
so if I buy these shocks and say a 2.5 in leveling block will I get a total of 4+ inches of lift?
Old 12-26-2010, 05:58 PM
Crash's Avatar
Rep:401
In theory yes but you almost certainly will be creating an angle problem on your front axle shafts leading to a dreaded death wobble problem. There really is no "shortcut" to getting that kind of lift. You will be much better of researching and buying a QUALITY lift kit that is engineered properly to deal with the angle issues. It will definately cost you more but in the long run be cheaper because you wont be tearing things out that don't work or cause damage or premature wear to your truck. I am not an expert and this is just my humble opinion.
Old 12-26-2010, 06:59 PM
Vehicle: 2010 RAM
so these trucks are still prone to the death wobble even with the new suspension design?
Old 12-26-2010, 08:35 PM
Crash's Avatar
Rep:401
Just take a look in the suspension lifting forum at the threads about leveling and see for yourself, there are quite a few members who have been unhappy with their results in using blocks or spacers to acheive a "level" truck never mind lifting them
Old 12-27-2010, 09:26 PM
vettaboy's Avatar
vettaboy vettaboy is offline
Vehicle: 2012 Ram 2500
Rep:35
vettaboy is on a distinguished road
My TRX has the HD shock package on it, if I put the Bilstein shocks on it will I be losing anything? I would love to have my truck level.
