Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-25-2010, 05:12 PM
bobodu bobodu is offline
Vehicle: 1997 Ram 1500
Color: Maroon/Silver
Rep:40
bobodu is on a distinguished road
Default Coolant leak..where from?
Appears to be dripping down between the engine and tranny. Nothing to be seen from the engine compartment and the floor is dry.
Old 12-25-2010, 09:47 PM
It could be dripping from the evaporator drain meaning a leaking heater core or a leaking freeze plug .
Old 12-26-2010, 07:33 AM
Rep:40
After I posted this, I thought about a freeze plug being in the bell housing. Rats... is it better to pull the tranny or the engine?
Old 12-26-2010, 10:14 AM
Well , thats gonna be a judgement call on your part . If it checks out to be a bad freeze plug , it's only a matter of time before other ones start to leak . If you have access to a lift and some special installation tools you can try to pull the trans and replace as many as you can get to .
Old 12-26-2010, 10:22 AM
Rep:4085
Freeze plug is what came to mind for me, too.
Old 12-26-2010, 11:35 AM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
There is a freeze plug on the back under the tranny bell housing. If it is coolant it may be coming from there. First check to make sure it's not your heater core going bad. The core could be leaking out through the weep hole on the firewall and get redirected due to air flow.
www.beatcraigslist.com - for posting dangers & secrets
Old 12-26-2010, 12:40 PM
Rep:40
Hot diggity dog...it's coming from the plug right in front of the starter!! At least that one... could be more, but the rest look good. Anyone know off hand what size that is? Couldn't get my calipers up in there but with my compass scribe it looks to be 1 5/8.
Old 12-26-2010, 12:47 PM
Not sure of the size , but before you knock the old freeze plug out , drain the radiator first , then theres a thread in plug along the side of the engine block . Make sure you have a drain pan under there and pull the plug first . You'll get a good gallon of coolant out of that side of the block . If not once you knock out the plug , you'll get covered in coolant .
Old 12-26-2010, 02:17 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
While you're changing that plug, I'd suggest changing all the plugs you can get to. Parts store should be able to tell you what size plugs you need. Of course getting them out in one piece if you can and marking where they came from is always the best option.
Brian:
Old 12-26-2010, 02:35 PM
Rep:40
I just can't believe none of the parts stores in town carries a 1 5/8 plug!!
Got a rubber one and it seems to be holding. Hope it'll last until it warms up or I can build or borrow a hoist to pull the engine. I'm gonna have to pull it and do all the plugs and clean the snot outta that block. Looks like there is a LOT of crap in her. Never should have built that wall in the shop. Can't fit the front end loader and the truck in.
