Old 12-26-2010, 12:18 AM
speedymph1000's Avatar
speedymph1000 speedymph1000 is offline
Vehicle: 1994 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Gloss Black/Silver
speedymph1000 is on a distinguished road
Default Smokin engine
My '94 5.2L is smokin when I first start it and when its at a idle for a long period of time. I'm sort of leaning againt valve stem seals. Anyone have any ideas on anything else. any help would be greatly thanked.
When in doubt use a hammer... The bigger the doubt the bigger the hammer!
Old 12-26-2010, 12:26 AM
Rep:2657
is there any pooled oil on top of your engine ??
Old 12-26-2010, 12:30 AM
No. I havent seen any. I maintain it regularly. My engine also stays very clean. It has 160,001 miles on it now
Old 12-26-2010, 11:16 AM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Rep:55
Ram15002ndgen will become famous soon enough
That is just your plenum gasket worn out. The engine is fine, no valves or seats to worry about. The plenum seal is the culprit in these engines. Your oils is escaping through the busted plenum and being burned up. You will probably notice some oil missing when you change your oil.
www.beatcraigslist.com - for posting dangers & secrets
Old 12-26-2010, 11:44 AM
I agree with Ram15002nd gen . Remove your air cleaner from the top of the throttle body , with the engine off , open up the throttle plate and look down to the manifold floor . See if you see oil puddling . If so , remove the intake manifold and reseal the plate on the bottom of the manifold . Heres a link that will help ya out . http://www.ramforumz.com/showthread....=plenum+gasket
Old 01-03-2011, 10:38 PM
Okay guys. Will do thanks a million. If thats not the culprit, what else could it be?
Old 01-03-2011, 11:33 PM
Rep:55
Then it becomes an internal issue. Rings, pistons, etc.
Old 01-04-2011, 01:30 AM
Will this gasket being wore out cause any noises to come from the engine? Tapping, knocking etc.? Also when I first change My oil it wont smoke until the oil gets some milage on it. Still may be that gasket. By the way thanks for the link, very informative description on how to fix it.
Old 01-04-2011, 11:01 AM
Rep:55
You'll get pinging from the engine due to a bad gasket. As for oil usage that can have anything to do with temps, oil viscosity, length of trip, type of driving, etc. If it's using oil I would say this is the most common problem. Measure your oil at the next change and you should see a quart or two missing.
Old 01-04-2011, 01:46 PM
When I changed it 2wks ago, it was about a quart and a half low, and I have no oil leaks anywhere. I'll be checkin this problem out and let Y'all know how it turns out. Thanks a bunch guys.
