Old 12-26-2010, 11:42 PM
2bornot2b 2bornot2b is offline
Vehicle: none yet
2bornot2b is on a distinguished road
Default 1500 towing
OK, so I'm looking at a 2011 1500 ST quad cab. Ads say capable of 10,450 lbs properly equiped. Does not say what that is. Anyone know what it takes to achieve that? Also is that realistic? Can't say much positive for the site.
Thanks
Old 12-26-2010, 11:53 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
It all depends how the truck is configured. Here's a link to the Dodge Body Builder's guide, you can play around with it to see what will do what.
http://www.dodge.com/bodybuilder/year.pdf
Brian:
Old 12-27-2010, 12:01 AM
Vehicle: none yet
Default 1500
I'm able to open the PDF file but for some reason the links don't work.
Old 12-27-2010, 12:06 AM
Proper tires for that load rating.
Proper class IV hitch
Proper anti sway and load leveling devices on hitch and trailer.
Brake controller
Brakes on trailer
Proper electrical connections.
Color: RootBeer
Rep:1287
Click on Body Builder's Guide at this link. https://www.dodge.com/hostb/crossbrand/owners/en/
Brian:
Old 12-29-2010, 10:34 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
Brake controller
Brakes on trailer
3.92 Gears!!!!
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 12-29-2010, 10:57 PM
Rep:2640
http://www.dodge.com/bodybuilder/201...wingbasics.pdf
Old 12-30-2010, 10:11 AM
Rec 26's Avatar
Rec 26 Rec 26 is offline
Location: El Paso, TX via Centereach, NY, Vieques, PR, and San Antonio, TX
Vehicle: 2014 RAM 3500 Crew Cab Dually
Trim Level: Tradesman
Color: Bright White Clear Coat
Rep:71
Rec 26 will become famous soon enough
Send a message via AIM to Rec 26 Send a message via MSN to Rec 26 Send a message via Yahoo to Rec 26
I got the chart printed out in front of me....
2011 ST Quad Cab...
3.7L V6:
3.55: 3,450lbs/8,500lbs
3.92: 3,450lbs/8,500lbs
4.7L V8:
regardless of tire size and gear ratio: 7,300lbs/12,500lbs
5.7 HEMI:
regardless of tire size:
3.21: 6,750lbs/12,000lbs
3.55: 8,750lbs/14,000lbs
3.92: 10,250lbs/15,500lbs
Note: Each one of those numbers is for max trailer weight/trailer GCWR and they are rounded down to the nearest 50lbs for max trailer weight.
Hope this helps out some.
2011 Ram 1500 Big Horn Quad Cab "SRT Hauler Mark I" (traded in)
2014 RAM 3500 Tradesman Crew Cab "SRT Hauler Mark III"
Old 12-30-2010, 12:19 PM
Color: RootBeer
Rep:1287
Good post Rec 26
Brian:
Old 12-30-2010, 06:19 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
It looks like the previous replies provided you the actual specs.
If you really will be towing amounts in the 10,000 lb range on a regular basis, I suggest looking at the 2500s if possible as the 1500 may not be the best suited for frequent towing of such amounts. It can do it but it may test your patience, expectations and reduce the life of your truck.
SB
