Old 12-31-2010, 12:53 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Originally Posted by SnowChief View Post
It looks like the previous replies provided you the actual specs.
If you really will be towing amounts in the 10,000 lb range on a regular basis, I suggest looking at the 2500s if possible as the 1500 may not be the best suited for frequent towing of such amounts. It can do it but it may test your patience, expectations and reduce the life of your truck.
SB
Just wanted to add, make that a 2500 with the Cummins. Better motor and trans for towing.
Brian:
Old 12-31-2010, 01:17 AM
Butter's Avatar
Butter Butter is offline
Vehicle: Ford owner as of 4-25-15
Trim Level: XLT
Color: Flame Blue Metallic
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
Originally Posted by Rec 26 View Post
I got the chart printed out in front of me....
2011 ST Quad Cab...
3.7L V6:
3.55: 3,450lbs/8,500lbs
3.92: 3,450lbs/8,500lbs
4.7L V8:
regardless of tire size and gear ratio: 7,300lbs/12,500lbs
5.7 HEMI:
regardless of tire size:
3.21: 6,750lbs/12,000lbs
3.55: 8,750lbs/14,000lbs
3.92: 10,250lbs/15,500lbs
Note: Each one of those numbers is for max trailer weight/trailer GCWR and they are rounded down to the nearest 50lbs for max trailer weight.
Hope this helps out some.
Those numbers are not the same for every truck, I have a 5.7 with 3.92 gears and my truck is not rated at 10,250 lbs for max trailer. The only way to be sure for your particular truck is to go to the body builders guide that Rootbeer linked and find the options for your truck.
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 12-31-2010, 06:27 AM
2bornot2b 2bornot2b is offline
Vehicle: none yet
2bornot2b is on a distinguished road
Default towing
Took the plunge a bought a new 2010 2500 diesel automatic standard cab long bed SLT. Towing issue solved.
Thanks for the input
Old 12-31-2010, 07:19 AM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
Smart choice.
I think you will find this baby will tow like a dream. Take some pics when you get a chance. I think the '10 2500s are a great looking truck.
SB
Old 01-01-2011, 10:28 AM
Rec 26's Avatar
Rec 26 Rec 26 is offline
Location: El Paso, TX via Centereach, NY, Vieques, PR, and San Antonio, TX
Vehicle: 2014 RAM 3500 Crew Cab Dually
Trim Level: Tradesman
Color: Bright White Clear Coat
Rep:71
Rec 26 will become famous soon enough
Send a message via AIM to Rec 26 Send a message via MSN to Rec 26 Send a message via Yahoo to Rec 26
Then you might want to double check your numbers then. That info that I posted I got off the body builder's guide. If you scroll all the way down where it displays the chart, there is a print icon. That's what I used.
I originally printed this out the day prior to my purchasing my truck and I double checked it by going back onto that site the day I orginially posted those numbers to verify.
Also if you look, I only displayed the info for the year and model that was requested.
2011 Ram 1500 Big Horn Quad Cab "SRT Hauler Mark I" (traded in)
2014 RAM 3500 Tradesman Crew Cab "SRT Hauler Mark III"
Old 01-03-2011, 02:56 PM
Vehicle: none yet
Default pics
Smart choice.
SB
Link to pics.
http://www.ramforumz.com/showthread....738#post398738
