96 1500 computer problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 12-27-2010, 01:10 PM
Guarva Guarva is offline
Vehicle: 1996 Dodge Ram 1500
Guarva is on a distinguished road
Default 96 1500 computer problems
96 dodge 1500 4x4. Started with 2 codes. idle air control for engine and overdrive solenoid, torque converter, electrical circuit for transmission(tranny all one code so could of been any of the three). replaced the IAC valve and suddenly tranny worked and no new codes. After 1 day started acting up again. Now truck wont run unless slight throttle is applied and then it lopes severely. No codes generate and in between lopes the gen light, engine light, and cruise light flash. Installed new firewall mounted computer and it ran perfect for about ten minutes or so then same problem.
Old 01-01-2011, 04:44 PM
philo philo is offline
Vehicle: 1999 Dodge Ram 1500 Quad
Color: Green/silver
philo is on a distinguished road
When you replaced the iac, did you clean the tb good? I f you removed the neg. batt. termnl. when you replcd the iac, the computer may need program, "learn" proper idle position again. See IAC cleaning procedures in threads.
