Old 12-27-2010, 05:12 PM
TxHouse TxHouse is offline
Color: Red Crystal Pearl/ Silver metallic
Rep:37
TxHouse is on a distinguished road
Default Installed Volant now engine light is on?
I installed the volant CAI on the 2010 ram and now my engine light is on and the eco light won't come on either, any ideas?
Audiocontrol LC8I, Focal 165krx2, Mosconi AS100.2 JL 12W6V2 X 2, JL 1000/1V2
Old 12-27-2010, 05:14 PM
Get us a code and we can surely help!
Old 12-27-2010, 05:29 PM
Rep:37
Do I need to buy a code reader or can I tell somehow without one?
Old 12-27-2010, 05:47 PM
Do you have EVIC? If so, you can read the codes doing a "Key Dance".
Here's the sequence and steps to the dance:
Get in the car, close the door. Perform the following steps fairly quickly (less than 3 seconds):
Turn key to ON
then back to ACC
then to ON
then back to ACC
then to ON
If there are any stored codes, they will appear immediately, in place of the odometer. For instance an "INTAKE AIR TEMPERATURE SENSOR CIRCUIT HIGH" error will set a code of P0113.
Once the codes have been displayed, you'll see "-----". If there are no trouble codes, the dashes will be the first item displayed.
After a few seconds, the display changes to "-dOnE-".
Old 12-27-2010, 11:29 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
did you put the iat sensor back in when you put the new cai in?
Old 12-28-2010, 02:43 AM
Juice420's Avatar
Juice420 Juice420 is offline
Vehicle: 2010 RAM 1500 SLT C.C.
Color: Brilliant Black Pearlcoat
Rep:946
Juice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to behold
I'm guessing the IAT sensor isn't pushed in all the way.
Justin
Black Mamba- Flowmaster 40 series, Airaid CAI, 20% tint, GTO taillight covers, ATA nerfs, AVS in-channel ventvisors, Curt hitch receiver, Extang Revolution Tonneau, EZ-down tailgate damper, Recon smoked 3rd brake light, Custom painted engine cover
Black Mamba's Thread
Old 12-28-2010, 03:06 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Either not pushed in, or is turned the wrong way. The open part of the sensor has to face the air filter.
Old 12-28-2010, 07:05 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
My guess is the sensor also. I installed my Volant and never had a problem. Let us know what you discover. Might also consider a Diablo Preditor also and it will read your codes as well as help other areas of power and performance. Best bang for the buck in my opinion.
Old 12-28-2010, 08:12 AM
Good point on the IAT sensor. Also, if the filter had a lot of oil on it, some might have gotten on the sensor. Some electrical component cleaner will do the trick.
Lastly, make sure all your connections are tight.
Most auto parts stores will read a code for you for $0
Old 12-28-2010, 04:42 PM
Rep:37
I'll check the IAT sensor, it is in all the way but it might be backwards, didn't think of that.
