Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Diablo Predator Questions & Info!
Old 12-27-2010, 10:56 PM
old hot rod's Avatar
old hot rod old hot rod is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Rep:386
old hot rod is just really niceold hot rod is just really niceold hot rod is just really niceold hot rod is just really nice
Send a message via Yahoo to old hot rod
Default Help With Diablo Sport Predator
Just added a Diablo Sport Predator to my Hemi. The tuner has different programs named by the octane of the fuel to be used. I went with the 93 octane, and it gave it a lot of takeoff, and it runs great. Then I went back into the tuner and changed my top speed to 120 and turned off that damn MDS. It has even more adjustments but I'm not smart enough to know what.
"Cooling Fans AC On or Off"
"Idle RPM AC On or Off"
"Part Throttle Upshift at 15% or 25% or 33% or 40% or 60%"
"1-2 RPM Upshift 5600 to 6200 rpm"
"Rev Limiter in Drive"
"Rev Limiter in Neutral"
"Throttle Sensitivity"
"WOT Fuel 1K-3.8K or 4K-4.8K or 5K-7K"
"WOT MBT Spark 1K-3.8K or 4K-4.8K or 5K-7K"
or "WOT Spark 1K-3.8 or 4K-4.8K or 5K-7K"
I know this is a long winding thread but I know there is a lot of knowledge on this forum and if anyone can help, it would really help me. Thanks
Hell Bent Steel Leveling kit, K & N filter, Tinted Windows,
Mufflex DOD18M, Mopar Intergrated Trailer Brake,
DiabloSport Predator (U7137) 180 Thermostat, WeatherTech Vent Visors
DiabloSport Catch Can (C-1040)
Old 12-28-2010, 03:28 PM
dylzsrt dylzsrt is offline
Rep:0
dylzsrt is an unknown quantity at this point
I am no guru on the predator for the Ram but do have one for my SRT8. On the SRT8's your better off running the 91 octane tune 9 times out of 10...even if you are running 93 gas. You get less knock retard running the 91 tune. Don't mess with any of the other stuff for now, until someone who's messed around a bunch can chime in. The canned tunes are good, alot of the other stuff involves having done more modifications. You can bump your rev limiter up a bit in drive if you want....don't bother with neutral. Run happily with the 91 or 93 canned tune for now.
Old 12-28-2010, 06:16 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
dont mess with spark or fuel advance. thats unless you really know what you're doing with that, and by reading your post you said you dont. i didnt mess with mine at all.
throttle sensitivity is how "touchy" the go pedal is. my throttle sensitivity is set to 15%. i like it to go when i just touch it.
i got my 1-2 upshift at 5800 and my other upshifts at 5600.
turn rev limiter in drive all the way up.
the rev limiter in neutral wont let you do over 4k rpm stock. i see no reason to up that.
i also did not mess with the cooling fan settings.
i run the 93 tune and it does good.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 12-29-2010, 11:05 AM
Rep:386
Thanks dylzsrt and cbrambo497, I was mainly trying not to screw up my truck. I got the predator for Christmas and after reading about a guy on the forum paying $5000 for a new transmission, I took mine back to the dealership to have it installed (trying not to kill my warranty). The dealer laughed and told me to save my money and put it in my self, and just take it out before I bring it back to the shop and he would never look or care if it had a programmer in it. So I did what he said. After installing and posting questions on the forum I called DiabloSport and told him what I had and what I've done. He explained everything I didn't understand and said the only thing I need to do was change out my thermostat to a 180 degree and adjust it in the program under the "Cooling Fan" and he said I would be done. Thanks again for y'alls help
Old 12-29-2010, 11:33 AM
Rep:0
Couple questions for ya, as I'm gonna be getting my predator shortly. What is the throttle sensitivitiy stock....is it at 0 on the predator and you go up in increments? What is the factory 1-2 shift point and the others set at?
I switched out my factory 265/70/17 tires, for 285/70/17's, does it have that setting for 285's?
Thanks
Old 12-29-2010, 11:39 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
I'm running the 93 tune with 93 gas..it's better to stay with the fuel you have a tune for. my throttle response is at 15% as well, up on the top speed. Didn't mess with shift points as I feel a valve body should be done before tinkering with shift points, JMO.
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 12-29-2010, 05:02 PM
Rep:0
I'll debate the fuel thing with you.Things may be different with the 5.7 but due to different quality in different gasolines...all fuels are not made equal.
Tons of dyno runs and data logs on the srt8's have proven the 93 tune often shows more knock retard and a loss of power over the 91 tune with 93 gas
Old 12-29-2010, 05:08 PM
Rep:386
Hi dylzsrt, what Mr. DiabloSport explained to me was that your stock sitting for throttle sensitivity is "0" and the "+15%" is 15% over stock and would make it jump a little quicker. I haven't yet but from what he said I'll up mine to +15% next time I play with it, and their is a adjustment for tire size I clicked on it and it gave a place to enter tire size "___ /__ /__" so I'm sure it will do what you need. Hope this helps, Thanks for your response.
Old 12-29-2010, 05:15 PM
Rep:386
After talking to Mr. DiabloSport he said if you get knock retard to drop back to the 91 tune and run 93 octane and wallah, no more knock
Old 12-30-2010, 03:25 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
