Old 01-03-2011, 07:29 PM
Gergas Gergas is offline
Vehicle: 2007 Ram QC 4x4 BigHorn
Rep:100
Gergas will become famous soon enoughGergas will become famous soon enough
Default Bilstein 5100 shocks w/strut extenstions?
This may be a stupid question, but here goes...can I use 2" strut extenstions AND the Bilstein 5100 shocks that are designed for a max 2" lift...for a total of a 4" lift? I'm guessing that there would be other suspension components that would need to be modified/replaced? Another question, if I use the Bilsten shocks would I need taller springs or do the stock ones just end up not as compressed? This is for my '07 1500 4X4 QC. Thanks in advance.
Old 01-03-2011, 07:36 PM
Rep:1625
If you want 4" of lift, go with a 4" suspension lift. A 2" leveling kit/Bilstein 5100 combo won't work, you're just asking for suspension problems.
Old 01-04-2011, 09:24 PM
ScatPak07's Avatar
Rep:970
I have to agree. You will really mess up the angles of the suspension components and the truck will run like crap and probably break some stuff. Dont look at the cheapest way to lift your truck. If thats the way you want to do stuff then the truck wont come out as nice as you want it to. Going higher then 2" would require a lift kit, or a 3" body lift. If you want to go higher then 2" then look at the Performance Accessories lift kit which is a 5" lift that incorporates a level + body lift, so 2" level and 3" body lift. That would be the cheapest way to lift the truck and you wont be asking for problems
The Bilstein 5100s just make the spring sit higher on the strut. That is what gives you the lift.
Which strut extensions are you talking about? I just would like to know what you are looking at getting
