MOPAR DECALS
Old 12-28-2010, 09:45 AM
parrothead's Avatar
parrothead parrothead is offline
Vehicle: 2014 Dodge Ram
Trim Level: black express
Rep:13
parrothead is on a distinguished road
Default Just two questions (for now)
How do I know the alarm is set.Per owners manual I hit the lock button on my key fob while the door was open.I then shut the door and opened with the key.There was no alarm.So i tried the panic button on the key fob and I definitely got the alarm.
How do I turn the heated mirrors on or off?
What does DTE on my EVIC mean?
Old 12-28-2010, 09:49 AM
iRESQu iRESQu is offline
Rep:2217
In the past, I learned that the "alarm" is set like so:
Roll down your windows.
Get out of the vehicle, shut and lock the vehicle.
Wait 10 (or so) sec.
Reach inside the opened window and lift the door handle.
That SHOULD set off the "alarm".
The alarms aren't activated by a bump to the body or even a window being broken out. They are activated once the window has been broken and access was gained through internal measures. I could be wrong, but give it a whirl. To shut it off, hit lock then unlock. I believe that should do the trick.
As for your heated mirrors, there should be a button on/near your a/c unit! I need to go look at mine, but it's really stinking cold out!
DTE=Due Till Empty, it's in relation to your fuel.
Old 12-28-2010, 09:55 AM
HVACeR HVACeR is offline
Color: Mango Tango
Rep:113
HVACeR will become famous soon enoughHVACeR will become famous soon enough
To activate your heated mirrors, look for the "defrost" button on your center console. This will turn on your heated mirrors, and if you have a solid back window, also turn on your rear window defroster.
MODS: BellTech 2/4, Air Lift 1000 Air Bags, Mufflex DOD14M, Partial Debadge, Pin stripe removal, B Pillar blackout removal.
Old 12-28-2010, 09:56 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
You can activate your heated mirrors by pushing in the knob that dials in your air flow ( i.e such as do you wish it to have defrost, to your feet, hitting you in the face etc)
Exco
Bill
tcarlton0516 tcarlton0516 is offline
Vehicle: 2014 Ram 2500 Crew Cab 4x4
Color: Blue Streak
tcarlton0516 is on a distinguished road
Don't know about the alarm system, but the heated mirrors can be turned on and by a button that looks like a rectangle with three curvy arrows pointed up through the rectangle. The same button turns on the rear window defroster and is located on the climate control panel. I believe it's on the mode control dial.
DTE= Distance to Empty.
Old 12-28-2010, 10:17 AM
Looks like you have your answers .
Old 12-28-2010, 12:24 PM
parrothead's Avatar
Rep:13
I have the defrost button and also have the power sliding rear window.So does this mean I dont have rear window defrost?
I thought that was what the DTE was,but yesterday I actually gained a mile or two at one point,so I guess the system takes into account the current MPG and makes adjustments.
Old 12-29-2010, 01:14 AM
HEMI5150's Avatar
HEMI5150 HEMI5150 is offline
Vehicle: 2010 Dodge Ram Quad 4X4
Trim Level: SPORT
Color: Black Pearl
Rep:35
HEMI5150 is on a distinguished road
R-E-E-E-E-E-E-E-E-A-D the Operators Manuel, it is ALL explained there, and in english too...!
You might be able to bullshit your way to the top, BUT, it wont keep you there
Never believe what you hear, and only half of what you see
Old 12-29-2010, 01:21 AM
Rep:2875
the owners manual will put you to sleep in 10 minutes because it so thick
as your sitting on the toilet , go through it, put away the Playboy mag
i have had my Ram since february '09 & its still teaching me stuff
Old 12-29-2010, 01:46 AM
parrothead's Avatar
Rep:13
How can a Mexican Hemi named Manuel explain anything in English?
