Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 01-01-2011, 01:44 PM
whitey543 whitey543 is offline
Vehicle: 95 Ram 2500 Cummins 4x2
Color: silver/maroon
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
whitey543 is on a distinguished road
Default 95 2500 Cummins towing cap.?
4x2, auto tranny (with aux. cooling), 3.54 rear end; having a heck of a time finding CGVW or max towing cap. I want to pull a 5th wheel, and am willing to put in an exhaust brake. Just need to know how heavy I can go.
Old 01-01-2011, 02:01 PM
No sticker inside the door or the glovebox?
You are right...I just spent 20 minutes web surfing/searching and NO INFO!!!
Old 01-01-2011, 02:16 PM
Default Not on door
The only thing listed on the door pillar is MGVW, 8800 lbs. I know that one 'rule of thumb' is to tow no more than the GVR, but does that assume 'no trailer brakes'?
I also noticed the pillar placard says to fill the front tires to 50psi, vs 80 for the back. My tires are all rated to 80psi; will filling them all to 80psi cause any problems?
I'll check inside the glovebox for any towing info there; thanks.
Old 01-01-2011, 02:21 PM
I've noted that towing capacities are higher for a 5vr vs. a tow behind too.
I'd keep the fronts under 80 psi and 50 is a good start. Once you get the trailer on the truck you can experiment a bit.
GVWR does not assume whether brakes are present or not. It is simply a measurement of how much the truck can haul, loaded. Basically the weight of the empty truck, add fuel, add passengers, add cargo, etc...
Here's a great site with some really friendly folks that can probably shed a bit more light on your truck and towing:
http://www.rvnetwork.com/index.php?act=idx
Old 01-01-2011, 02:35 PM
I understand what the GVWR is: it is what the truck is allowed to weigh itself. What I cannot find is the CGVWR - max truck plus trailer rating - although I'll look in the glovebox. It may well be GVWRx2, or 17600.
Old 01-01-2011, 02:39 PM
Sounds about right. I towed a 5vr with a GM diesel and tried to stay under 14K
