Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
ZDOG
Old 12-28-2010, 04:01 PM
billw billw is offline
Vehicle: 2005 Ram 3500 Laramie CTD
Color: Almond
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
billw is on a distinguished road
Default Dual Zone Climate control issue
I have an 05 Ram 3500. The dual zone climate control is behaving a little strange. The drivers side will blow hot on defrost only. If moved to the feet or dash it will go much cooler. The temp control responds if I move it to cool but when on hot it is warm at best. As I said before on defrost it blows hot, as the passenger side. If I put it on recirculate it blows warmer but still not hot. I have found very limited information on the dual climate control. I am not wanting to pull my dash apart without at least exploring every possible fix first.
Any help would be appreciated.
Old 12-31-2010, 01:55 PM
Resident Technician
Rep:1911
You probably have a broken blend door for the drivers side.
Old 12-31-2010, 03:18 PM
Color: Almond
Thanks. Is there any way to trouble shoot that without taking it apart?
Old 12-31-2010, 09:29 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Get someone to help you. You crawl down under the dash and have them operate the controls with the engine running. Using a flashlight look for the actuator arms moving.
Have the person put the controls in each mode so you can see what the arms are doing for each one.
Brian:
