Old 12-28-2010, 06:30 PM
sinistersix sinistersix is offline
Vehicle: 2011 Ram Sport
sinistersix is on a distinguished road
Default 20x10 or 20x8.5 KMC rockstars on 5" Lift?
Total noob when it comes to wheels and backspacing. I am looking at the 5 inch body lift from PA. I want to get the KMC rockstars but not sure which size to get. I would get 20x10 if they will fit, but not sure if that means getting 35x14.50 or 35x12.50. I want the tires to be as wide as possible without rubbing.
Also not sure about the whole back spacing thing, can these wheels be ordered in different backspacing setups or do the KMC Rockstars come in one back spacing size??
Old 12-28-2010, 07:26 PM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
I would go with 20x10. You can run a 35x13.50r20 on them.
SUL73NAZ
Old 12-29-2010, 03:14 AM
so 35x13.50s will fit with zero rubbing on the 5" pa premium lift?
Old 12-29-2010, 01:01 PM
SUL7ENAZ's Avatar
Color: blue
Rep:463
yessir!...
SUL73NAZ
Old 12-29-2010, 04:51 PM
and you know this how...got pics ?
So do wheels come in one backspacing or does that need to be determined when ordered? I would love to do 20x10s...
Old 12-30-2010, 04:10 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
Look here:
http://www.kmcwheels.com/html_pages/xdseries.html
Open up the rockstars specific icon and it will go over sizing and bolt patterns and also the offset/backspacing question for you.
For example a 20x10 is -24 offset and 4.56 backspacing and 20x8.5 is +10 and 5.14 backspacing. I think our trucks come with 5.00 backspacing if I remember correctly? So the 4.56 will make the tires stick out further from the frame and the 5.14 will tuck under the fender and closer to the frame.
Old 01-03-2011, 01:02 AM
ScatPak07's Avatar
Rep:970
Go with the 20x10 and the 13.5" wide tire. That is going to be the best set up for you.
Old 01-03-2011, 02:51 PM
Nice, would be tight if someone had a pic. I want the wheels to stick out but not super far
Old 01-02-2013, 06:22 PM
itshertruck's Avatar
itshertruck itshertruck is offline
Vehicle: 2012 Dodge Ram 1500 CC
Color: Tequila Sunrise
Rep:15
itshertruck is on a distinguished road
Send a message via AIM to itshertruck
Not to hijack the OP's thread, but I am looking at a set of MB Gunner 5 series rims, 20x8.5with an offset of +25. No idea what the backspacing is. What is the max size tire I can run on that?
If it's too loud, You're too old!!
Dodge the father and RAM the daughter!!!
Old 01-02-2013, 07:42 PM
Phildo's Avatar
Phildo Phildo is offline
Vehicle: 2011 Ram Sport 4x4 QC
Rep:42
Phildo is on a distinguished road
Those would not even fit your truck. They would rub on the ball joint and look retarded. You need a lower offset wheel to push the wheel and tire out further.
Stock is 20x9 +18 offset. 20x9 0 offset is good to fit wider tires up to a 35x12.50r20 with a levelling kit or a 33x12.50r20 stock height
