Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
tonneaucovered.com
Old 12-28-2010, 08:52 PM
bcjjones bcjjones is offline
Gender: Not Specified
Rep:13
bcjjones is on a distinguished road
Default Fuel Pressure?
So i've still been trying to figure out why my truck keeps just dying while driving. sometimes starts right back up, sometimes takes a while then starts right up and runs fine. Well i rented a fuel pressure tester but not sure what the pressure should be for a 1996 dodge ram 5.2? I've read two different answers but figured someone here would know for sure.
I'm pretty sure its not the fuel pump, but just wanted to make sure its in the right range while I have the pressure guage.
I'm pretty sure it was the ASD wires. I was running threw all the PCM wires once again, and the ASD wires just randomly caught my eye. There is two of them and they were just kind set down by the ground wire that runs from the battery to the engine block right above the power steering pump. The two ASD wires were just twisted very loosely together, and I figured that they probably are the source of my long long headache because im sure they are just coming apart enough to loose contact and shut the engine down. So im goin to fix that but my question is arent the two ASD wires supposed to bolt down with the ground wire on the engine block that is coming from the battery?
Sorry to be so long winded but im excited I might have figured it out. And thanks for all the help fellas, I couldnt have done it without yall!
Old 12-31-2010, 10:34 AM
Resident Technician
Rep:1911
Which ASD wires? What color is the wire?
