Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-28-2010, 10:00 PM
doug123 doug123 is offline
Vehicle: 1995 ram
doug123 is on a distinguished road
Default water sound
man i just bought this truck and after awhile i started hearing a water noise [gurgle] on passenger side thought heater core but no water leaks. it's making me crazy.
Old 12-29-2010, 03:15 AM
bradybrat77's Avatar
bradybrat77 bradybrat77 is offline
Vehicle: 2001 Dodge Ram 1500 5.9
Trim Level: Unmarked
Color: Blue
bradybrat77 is on a distinguished road
i have the same problem, i tried to top off all the fluids and had no result. I've had my truck for about a year now and it started making that gurgling sound about a month after i bought it. it hasn't affected my trucks preformance though so I just turn the radio up louder. i would be nice to know the cause of it.
Old 12-29-2010, 11:37 PM
Todd F's Avatar
Todd F Todd F is offline
Vehicle: 1997 Dodge Ram 5.9L
Trim Level: SLT Sport
Todd F is on a distinguished road
I've always had that sound coming from my heater core on my f-150. It's only noticeable after I turn the truck off, so I have never worried about it.
Old 12-30-2010, 03:01 AM
Rep:2804
sounds like you have air within the heater system
maybe try burping your top radiator hose a couple times
i believe it is done by squeezing the hose, someone will explain it better hopefully
Old 12-30-2010, 12:23 PM
audiophile's Avatar
audiophile audiophile is offline
Vehicle: 1998 Dodge Ram 1500 Club Cab
Color: Blue
audiophile is on a distinguished road
I have this too, started after I replace heater core. Water system is full. I have read other comments also in other forums that I read. Seems to be a common thing. Don't know if it is a real issue other than being annoying.
They say hard work never killed anyone, but why chance it?
Old 12-30-2010, 01:18 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Yup, air in the heater system. Flushing the whole cooling system will usually fix it. But if you use to much pressure it is possible to bust the heater core (especially on a 15 year old truck) which is not an easy fix nor fun.
If you can live with it until warm weather hits, then go for the flush. At least that way you won't be freezing your arse off while working on it if you do bust the core.
Given the age, its probably due to for a cooling system flush and t-stat change anyway.
Brian:
Old 12-30-2010, 09:40 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I've had this issue myself and nothing I've done as far as purging the systtem or sitting on a hill with the radiator cap off seems to work. Just when I think it's gone the bubbling returns. I almost wonder if I haven't got a cracked head.
Old 12-30-2010, 09:44 PM
Vehicle: 1995 ram
thanks i'll give it a shot
Old 12-31-2010, 12:19 AM
Sounds like you guys are low on coolant . Make sure that the radiator is full when the truck is running . Be careful not to open up a radiator once it's hot . Be careful .
Old 12-31-2010, 01:03 AM
Color: Blue
I've checked the radiator and added more coolant into the resivour, the sound goes away for a lil bit but in a day or so the resivour is dry and the bubbling sound comes again
