Old 12-28-2010, 10:16 PM
PegCityTRX4 PegCityTRX4 is offline
Trim Level: CC TRX4
Rep:13
PegCityTRX4 is on a distinguished road
Default Windshield leak
So I washed my truck the other night (not that it matters, it's filthy again already) and I noticed something very upsetting. My windshield was leaking water from the top, two streaks of water ran down on the inside. On top of this I had some water leak through the top screw holes on both sides of the a-pillar handle.
Ever heard of this? I have an appointment on Jan 8th at the dealership to get it looked at...but any insight would be appreciated!
Old 12-29-2010, 09:46 PM
JRI JRI is offline
Vehicle: 2010 Ram Crew Cab
Rep:14
JRI is on a distinguished road
Apparently you have a bad seal. It happens but they should be able to fix it.
Old 12-29-2010, 10:19 PM
Rep:2657
it happens with the Rams a lot more often than you would think, the dealer will fix it.
the machine that applies the sealer sometimes gets a air bubble & misses a very small spot where no compound is applied
it can happen to front & rear windows & around the outer cargo light
Old 12-29-2010, 11:02 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
had this same issue but on the side.....looked like someone bumped into the robot.....either way this repair should be carried out by a glass company as the dealer will not have the correct butyl sealer.......also if the repair is made from the inside there will be less potential for damage.....inner trim pieces are alot more friendly.....
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 12-29-2010, 11:07 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
That sucks, let us know how the repair goes.
Old 12-29-2010, 11:10 PM
Rep:2657
the dealerships body repair dept, has the right sealer & it will be fixed under warranty
Old 12-29-2010, 11:36 PM
It sounds like you have nothing to worry about . Keep us posted .
Old 12-30-2010, 09:23 PM
Trim Level: CC TRX4
Rep:13
Well, according to them they've never heard of this happening before. I'm sure they will fix it.
You would think that some sort of seal testing would be done before it is sold...
