Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 12-28-2010, 10:20 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Default Throttle response ?? for Ram Tech
I've read a little on the throttle response in the 5.7. My truck take .5 to .75 sec (seat of the pants feeling) to respond when I mash the gas from a stop. From what I've read this is torque management working, so my question is besides buying a predator is there any way to get rid of or minimize this? such as this procedure (or is this just another imagined fix like the steering wheel rotation press and hold the traction control button to totally turn off traction control???)
......Regarding throttle calibration...
I'm not certain if it works on the truck... but I am certain it works on the 5.7
in the challenger....this information from another forum and I can certainly
verify that it DOES make a nice change! It only takes about a minute... give it
a shot on your truck...nothing to lose!
Dodge provides these instructions regarding pedal response...
1. Insert key into ignition and turn to the ON position (do not start the car)
2. Press the accelerator pedal to the floor ... then release.
3. Turn the key to the OFF position.
4. Proceed to start and drive the car.
If your throttle was not calibrated, you should notice an immediate improvement
in throttle response. We noticed a performance increase and a flat or dead spot we
had previously had in the throttle disappeared.
I would just add three things about the throttle recalibration:
After you insert the key and turn to "ON" not start, wait for all the idiot lights
to go out. (Ck Eng Light may remain on).
After you depress the accelerator pedal to the floor, hold it for about a three
second count. (On some PCM versions, CkEngLight may start flashing here)
Most drivers notice an immediate change in throttle response, but depending
on your driving style, you may need to repeat this procedure periodically
due to the computer's adaptive programming.
Old 12-28-2010, 11:16 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
I'm not Ramtech but I'd double check whether the Predator can adjust Torque Management if that is your reason for buying it.
Brian:
Old 12-29-2010, 12:13 AM
Crash's Avatar
Rep:401
From my reading I've discovered that you can get a custom tune to remove some but not all of the torque management. I have not contacted diablo directly yet to confirm or get a price for this service. but it would be one of the main reasons for me purchasing one
Old 12-31-2010, 12:46 AM
jdlatil's Avatar
jdlatil jdlatil is offline
Vehicle: 2010 Dodge Ram Crew Cab
jdlatil is on a distinguished road
Superchips can control the torque management. Really have not had time to play with it yet.
2010 Crew Cab Bighorn Hemi, F1, Bedrug, SC 93 tune, 3.92 & Detroit Locker, K&N. 14.37 @ 96 mph
Old 12-31-2010, 01:14 PM
Crash's Avatar
Rep:401
Thanks for that info I did not know this. I guess I need to do some reading on the superchips before deciding on a programmer. I am not going to buy on before spring anyway, I feel that a tune would be a waste of power for winter around here.
Old 12-31-2010, 01:24 PM
Rep:1882
There's no way that I'm aware of to turn off any torque management functions without the use of a tuner.
Old 01-03-2011, 07:31 PM
Crash's Avatar
Rep:401
Thanks for the clarrification Ramtech. This is what I thoght but just wanted to get it from an authority on the subject, there is a lot of good info on the net but sometimes being sure what is good info and BS is hard know which is which!
