Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
tonneaucovered.com
Old 12-29-2010, 03:14 PM
sudsy's Avatar
sudsy sudsy is offline
Vehicle: 2009 Dodge Ram
Rep:97
sudsy will become famous soon enough
Default daystar leveling kit question
Hi there, im looking at purchasing a daystar 2.5 front, 1.5 back leveling kit/lift.
I am wondering if anyone has put one in there truck, and what was the Actual Lift obtained?
thanks!
Old 12-29-2010, 04:21 PM
awful knawful awful knawful is offline
Vehicle: 2009 RAM 1500 CC 4X4
Rep:24
awful knawful is on a distinguished road
I have the kit in my truck. I put it on myself. I can't really measure it cause I have on my 265/70/17 winter tires. This pic with 20s will give you an idea of the front, but the back tire is in a bit of a hole. The truck is almost perfectly level.
Old 12-29-2010, 04:54 PM
sudsy's Avatar
Rep:97
Hey thanks for the reply im hoping someone can take a measurement that has this installed i measure 39" rear and 37" front. Your truck looks great im hoping to get it put in a few weeks!!! If anyone has tjis installed and can let me know actual gains in onches that would be great!!! Oh i have 20 inch stco rims and tires.
Old 12-29-2010, 06:04 PM
Thetolleyman Thetolleyman is offline
Vehicle: 2003 Ram 1500 Quad Cab
Color: Gold/Silver
Thetolleyman is on a distinguished road
I put the Daystar 2.5 inch thick front spacers, and gained 3.25 inches in total height measured under the center front of bumper.
[03' Ram, K&N FIPK, Electric fan conversion, Fast Man TB, Superchips tuner, Magnaflow cat-back, 08' intake, 1" body lift, 1.5" coil spacers, 3" lift spindles, 1 1/2" block on rear, rear leaf flip,. [/SIZE]
Old 12-30-2010, 12:36 AM
sudsy's Avatar
Rep:97
Thanks for the reply!!! Cant go wrong for the price. Is the install easy enough to do it yourself or should i just let the shop do it?
Old 12-30-2010, 09:14 AM
Color: Gold/Silver
Default Daystar lift
It took me approximately three hours. You'll need at least two jacks and spring compressors are helpful. I borrowed the compressors but couldn't use them because they were the type that need to go up the center of the spring, you'll need the type that grab from outside of the spring only.
In the end I just removed both upper and lower ball joints and was able to get the spacer and spring in without much trouble. I have seen plenty of post here though that claim it nearly impossible without compressors. I have a 2WD perhaps its more difficult on a 4WD.
Old 12-30-2010, 09:22 AM
Cowboy's Avatar
Cowboy Cowboy is offline
Vehicle: 2015 Ram 1500
Trim Level: Express Quad 4x4
Color: Maximum Steel
Rep:14
Cowboy is on a distinguished road
I'm about to pull the trigger on something. Trying to weigh all the options. Obviously a lift kit will cost more. I've heard good things about the leveling kits and just needing a an alignment afterwards. The lift kit would allow me to go up in tire size, which would be a plus. Bit with motorcycle roadracing season coming upon us soon enough I may need to pass on spending the extra funds. Keep us posted!
2015 Dodge Ram 1500 Express, 5.7 Hemi, 4x4, Maximum Steel, Quad Cab
Old 12-30-2010, 05:10 PM
Rep:24
I put mine in myself with 2 jackstands, a floorjack and basic hand tools. I didn't need the spring compressor, but it would of helped to have one.
Old 12-30-2010, 05:12 PM
Rep:24
I'll try and get a measurement from the middle of the wheel to the lip of the fender. If you take the same measurement it should give you a rough idea of the total lift.
Old 12-30-2010, 05:53 PM
sudsy's Avatar
Rep:97
That would be awome!! Thanks
