Nice battery. I use my trucks for snow plowing, which is one of the most intense uses of a truck battery (I believe the electric plow motor uses about 350-450+ amps when angling or raising the blade). I have used DHs, which have performed well over the years. I have also found the NAPA 1100 CCA battery to be a heavy-duty contender as well.
i got it because of the warranty and it was only 1 of 2 batteries that used agm technology. optima was the other but has been getting bad reviews since they moved to mexico. i may need a starter too.
Thanks for posting this, I'm gonna need a battery soon. The warranty on this is much better than Optima 4 year replacement and 100 month pro-rated warranty compared to Optima's 3 year warranty. Plus the reserve capacity is 135 minutes and 930CCA is crazy!:smileup:
