Ball Joint Replacement - What Kind and How Hard? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 12-30-2010, 10:16 PM
doozy doozy is offline
Vehicle: 2007 Mega Cab 5.9L Cummins
Trim Level: SLT 2500 4x4
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
doozy is on a distinguished road
Talking Ball Joint Replacement - What Kind and How Hard?
I'm being told I need uppers and lowers. Is there a certain brand I should be shopping for? The prices seem to range from $33 for a FULL set on Ebay, to $130 each through local auto parts stores. The ones that are adjustable or offset seem to be about double the price of the regular ones. I'm not sure if I need those or not. I have a 2.5" leveling kit.
Also, is it a complicated task to change these? I've ripped apart suspensions before on cars and toyotas, but never on a full size dodge. Any special tools required?
Any help is appreciated.
jh
Old 12-30-2010, 10:38 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
Replacing upper and lower ball joints is somewhat involved on any 4-wheel drive vehicle (if not very involved) depending on your mechnical expertise. You do need certain non-routine tools to do the job right. Of coure you need an alignment too once they are together. If it were me, I would have a professonal do it as you don't want to get it wrong since it is someting that can spell disastor.
Old 01-01-2011, 09:02 PM
tank120 tank120 is offline
Vehicle: 1998 Ram 1500 4x4
Trim Level: Laramie SLT
Rep:13
tank120 is on a distinguished road
Im not 100% on the offset but definitely go with the better quality, you get what you pay for (most of the time) and ball joints are not something you want to penny pinch on. If you plan on doing ALOT of off roading, check out Carli Suspension's web site, they have quality, rebuildable ball joints that are race proven.
Old 01-02-2011, 01:04 AM
Rep:3347
Look for the Moog joints, they are greasable, which for the life of me, I can't see why chrysler didn't allow for any kind of servicing on them.
Old 01-02-2011, 06:31 PM
dodgeguy's Avatar
dodgeguy dodgeguy is offline
Vehicle: 2000 Dodge Ram 1500
Rep:61
dodgeguy will become famous soon enough
I'm not sure about the newer models, but on my second gen, the ball joints were riveted on.
I changed mine a couple of weeks ago, and it took forever.
I had to grind off the heads of the rivets, drill them out, and then pound them out with a hammer.
I would take it and get a quote.
If, like me, you were quoted $1400, do it yourself.
But if you get a quote for less than $600 or $700, let the shop do it.
"If it's smaller than a 5-cyclinder, it's just a glorified motorcycle engine."
Old 01-02-2011, 06:40 PM
I agree...look for MOOG or NAPA ball joints which are greasable.
It's pretty straight forward. If you have the originals they are probably press fit in and riveted so you'll have to press the old ones out.
Good luck!
Old 01-02-2011, 11:55 PM
Mcbride's Avatar
Mcbride Mcbride is offline
Vehicle: 2011 ram 1500 Crewcab 4x4
Trim Level: Sport/SLT
Rep:13
Mcbride is on a distinguished road
Moog, they are the best.
Changing them is not too hard, but I suggest taking it to an alignment shop once back together, and have it checked.
Its not a mistake that mans best friend cannot talk.
Old 01-06-2011, 03:09 AM
Thanks for all the info and help. I went with MOOG ball joints. I also need front drive axle U-Joints and it doesn't look like MOOG makes those. Is there any brand I should look for on those? Thanks again.
jh
Old 01-06-2011, 01:26 PM
Mcbride's Avatar
Rep:13
Spicer has worked well for me over the years.
http://www.spicerparts.com/driveshaft/automotive.asp
Old 01-07-2011, 12:37 AM
marcoc marcoc is offline
Vehicle: 2009 Ram 2500
marcoc is on a distinguished road
Quad4x4.com, google search they have u-joints and ball joints for the AAM axle.
