5.7 Hemi Break-in Period and mileage? - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-27-2011, 09:32 PM
bgerard's Avatar
bgerard bgerard is offline
Trim Level: Big Horn 4x4 Crew
Color: Austin Tan Pearl
Rep:28
bgerard is on a distinguished road
2700 Miles, now averaging 16 per combined rural/city. Its up from about 14 from brand new. Keeps getting better over time and I'm not too gentle on pedal.
Old 03-27-2011, 09:43 PM
CCeastside's Avatar
CCeastside CCeastside is offline
Vehicle: 2010 RAM SLT 4X4
Trim Level: SPORT CREW CAB
CCeastside is on a distinguished road
mine the magic milage was 15,000 also MPG did go up 1-2 in town... now it's high 13 to 14+, was 12-13 and hwy not so much still i'm getting 17-19 .. many things effect MPG, and i have the 3:55's in the rearend, with cold air kit... the DPS Tune will my next mod then will see what happens
Old 03-28-2011, 11:25 AM
bhc1980 bhc1980 is offline
Vehicle: 2012 Dodge Ram 1500
bhc1980 is on a distinguished road
The gear ratio has a big impact on mileage. My truck has MPG friendly 3.22 gears and I have averaged between 16.5-18.5 since my first oil change (Mobil 1 syn) at 500 miles. I am completely stock right now. Been thinking about switching to 3.92 gears for a little more out of the hole but gas is almost $4 a gallon here and I am enjoying the decent mileage. I use the hell out of my cruise control which really helps control the lead foot problem the hemi's seem to produce.
In my 05 hemi I had 3.92 gears, intake, exhaust, supechips and average 14 mpg. Up from 12 when the truck was brand new.
Old 03-28-2011, 07:37 PM
SCHP52Ram SCHP52Ram is offline
SCHP52Ram is on a distinguished road
Aviator
I have about 9400 miles on my 2010 Ram. What I have found is just what you said, if I set the cruise it gets about 20 miles to the gallon. I have found that if I dont set the cruise and drive the truck where I control the gas pedal I can get 22 and some times 23 on a good day. Now that is on the highway and not going much above 70. Around town I have had to slow it way down to get 17 to 18 but have been able to get it . I have only replaced the muffler and taken the recinators off so not much of any upgrades as of yet. Not sure this helps but I sure hope so. Oh yeah one of your questions was if I saw it improve as I put on more miles. Yes I would say for me that is a true statement. Good LucK
Duck J
Old 03-28-2011, 08:03 PM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
Originally Posted by HEMI5150 View Post
These vehicles today are designed around the E10 & E15 ethanol blended gasoline,
so straight gasoline isnt gonna make much difference unless you add ignition timing.
Also, after a few oil changes, (and using a GOOD grade of synthetic oils) you`ll notice a slight MPG increase.
At 5,000 miles, its pretty much done all the major break-in you`ll ever see. Check your tire pressure too,
tire pressure makes a huge difference, type of tire will make a big difference too.
Check the air filter often too, critters like to make nice homes in there.
Ignition timing isnt the primary issue. The primary issue is the proper AFR and the truck does have 02 sensors and the PCM will readjust to avoid the vehicle running to rich on G100.
In the old days cars knocked on E10 primarily because they were running to lean. Reducing ignition timing would help "bandaid" the problem but ideally the mixture would have been richened.
E10 or E15 will cost roughly 1 mpg.
Gene
Old 03-28-2011, 10:10 PM
Todd05's Avatar
Todd05 Todd05 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:39
Todd05 is on a distinguished road
Just took my first highway trip put on about 500 miles round trip and i was getting about 17.5 mpg and my truck only has about 2000 km on it, so I was very happy so far, with the milage it got.
Old 03-29-2011, 01:04 PM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2016 RAM 3500
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
Rep:48
rsg1963 is on a distinguished road
You bought the wrong type of vehicle, and the wrong motor on top of that, if you sweat 4-5 MPG difference. We all want 400 + fp of torque AND 25 MPG highway, but unless you go Diesel, it ain't happening. I average 13 MPG, hand calc. And I get, at best, 18 Highway with it under 70 mph. My gears are 3:92 and I wish they were 4:10's or higher (numerically). I have a lot of tire and a leveled truck so my gears hurt my mpg since my engine lugs @ 65 in OD. Lower RPM, due to gearing, on the highway eventually has diminishing returns, and add to that the fact that lower (numerically) gears kill city driving mileage. Hence my wish for higher gear numbers. 4:56's would be perfect, plus it would only add to my towing ease and mileage.
2016 3500 Laramie MC 385/900 with Aisin tranny & 4.10 gears: Bilstein 5100's up front, 20" Fuel rims with 275/65-20 Micheline LTX MS/2 tires, Weathertec Floor mats, 45 gal RDS tank, Hensley TS3 hitch, Billet DEF and Diesel caps, DeeZee tailgate assist, Bull Ring retractable stake pockets, Amp Research steps, hybrid window tint.
Old 03-29-2011, 10:26 PM
MaxRam2010 MaxRam2010 is offline
MaxRam2010 is on a distinguished road
I just took a trip to Vegas and was able to get 18.2 miles per gallon. Granted i was dealing with a huge amount of morons on the road that couldn't drive if there lives depended on it, and in between stepping on the little pedal and leaving asphalt in their grills, I am very impressed with the MPG i got. The truck ran strong and had no problems overtaking the chumps as needed!! BTW first Dodge and never going back! Only issue i had was a whistling noise from the drivers side doors at around 80-85 plus mph. Don't mean to hack this page, but has anyone else had this issue?
Old 04-06-2011, 08:44 PM
Aviator23's Avatar
Aviator23 Aviator23 is offline
Rep:31
Aviator23 is on a distinguished road
I have the whistiling issue too. I notice it at around 75mph in gusty winds. I told the dealership about it on my first oil change so they ordered me a new door seal. I haven't brought it in yet to get fixed.
