Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 12-31-2010, 08:12 PM
kinghd kinghd is offline
Vehicle: 1992 Dodge 2500
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
kinghd is on a distinguished road
Question Another steering problem.
I just replaced the steering box on my '92 2500. All was working good for about two week but now it's pushing fluid out of the cap. What would cause that?
Old 01-01-2011, 01:41 PM
Jersey Devil's Avatar
Jersey Devil Jersey Devil is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Metalic Silver
Rep:50
Jersey Devil will become famous soon enough
Was it a new pump or used?
Did you prime it properly and bleed it before using?
Did you over fill it?
If new, you primed and bleed it and it wasn't overfilled I would think its the pump again. Check all you lines and make sure return isn't pinched or crushed.
If you didn't prime it or bleed it then you fried the pump.
Old 01-01-2011, 02:37 PM
Default Another steering problem.
I didn't change the pump just the box and new lines. I did prime and bleed it. Like I said, used it for two weeks and it worked perfect. I'm thinking the pump took a crap. Just wanted to get another opinion.
Old 01-01-2011, 02:41 PM
Try bleeding it again...just back and forth to steering lock both ways a few times, check fluid level, add as needed, back and forth again, repeat...
But you may be right...if it's blowing fluid up through the cap and it was bled, sounds like the pump is not sending fluid to both sides of the valve body and it's over pressuring.
Old 01-01-2011, 02:49 PM
Yeah, I'll try it again. Ahhhh, the joy of owning an old truck. LOL
