Old 01-01-2011, 09:39 AM
imrentman imrentman is offline
Vehicle: 2000 Dodge Ram 2500 HD Diesel
Trim Level: Laramie SLT
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
imrentman is on a distinguished road
Default 2000 2500 Diesel Stick Won't Crank, Help!
I'm brand new here and want to throw out a question. I have a 2000 Ram 2500 Diesel 6 speed stick with 43K. Push the cluch in to start & get nothing. I get all power accessories to work & no voltage drop when I turn the key to start. I banged on starter & got nothing. Where & how do you check the clutch saftey switch? Can I jump it out? Also I don't hear the lift pump spraying fuel when I turn the key to the on position. Any fuses I should check. Anyone ever had this problem? You thoughts would be appreciated. Thanks!
Old 01-01-2011, 02:52 PM
Jersey Devil's Avatar
Jersey Devil Jersey Devil is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Metalic Silver
Rep:50
Jersey Devil will become famous soon enough
I would check all the fuses first then try to jump the switch. I believe the switch is at the pedal under the dash but not sure you will need to get under and take a look.
Good luck and keep us updated.
Old 01-04-2011, 10:44 PM
Update: Got the truck running. Found a mini 20 amp fuse marked "starter" under the hood in a big black fuse box blown. Replaced it & it fired up. I have no idea why that blew. I'll drive it & see what happens. Thanks for the advice. Got to say this truck has been a problem from brand new day 1. Not like my other truck, a perfect running 1983 Dodge Ram B350 maxi van with 283K miles on the original 318. Now that is a trouble free Ram tough truck. They really don't make them like that anymore.
Old 01-10-2013, 06:59 PM
dealznik dealznik is offline
Color: brown
dealznik is on a distinguished road
I just had the same problem and like you i bought new batteries then took off the starter and checked the plunger and contacts and the starter was fine, i then checked the starter relay and also it was good....after i read this i went out and sure enough that little 20 amp was blown.
