Old 01-09-2011, 06:39 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Is there any benefit in running the JET over the cheap-o?
Old 01-09-2011, 06:48 PM
autobred's Avatar
autobred autobred is offline
Vehicle: sold* 10' R/T... 13' R/T
Trim Level: R/T
Rep:142
autobred will become famous soon enoughautobred will become famous soon enough
cant answer that bro, but I did read on the other boards is that you have to watch out for the fitment and also some of them doesnt have a little check valve (bleeder) built on them. Heres a pic of the stock one (left) and the jet. It should look similar when your buying. Hope it helps
Old 01-09-2011, 06:50 PM
916Timmy's Avatar
Rep:1443
Thanks for the pic!! I owe you a ton of rep points!
Old 01-10-2011, 07:23 AM
Ron J's Avatar
Ron J Ron J is offline
Vehicle: 2006 Ram
Trim Level: TRX4
Rep:36
Ron J is on a distinguished road
Am I missing something? I read a lot about people not wanting the 180 t-stat in the winter. If it is working correctly, the engine will warm up the same no matter if there is a 180 or 280 stat in it. It's just a matter of how hot it will get before it opens. I can't see anyone seeing any differences in heating capabilities between 180 and stock.
2006 RCSB Hemi Ram 4x4, CAI, Superchips, Pacesetter LT's w/ ORY and cutout.
Old 01-11-2011, 03:14 PM
jbchoice1 jbchoice1 is offline
Vehicle: 06 Big Horn Quad Cab
Trim Level: SLT Big Horn 4x4
Rep:14
jbchoice1 is on a distinguished road
Originally Posted by gabrieldy View Post
For those of you that are interested in a 180 degree t-stat I found another option after doing some reading on the lxforum.
The Autozone p/n 4128 fits perfectly. It is made by Motorad which is the same company that makes the Jet thermostats...so I'm told. Oh and it's only $15!
I swaped mine out this moring in about 15 mins. The coolant that I wasn't able to catch I replaced with a bottle of Water Wetter and a little bit of water. I'll be using 190 and 200 for the low/high speed fan settings. The Autozone 4128 t-state doesn't come with a new rubber o-ring so you need to reuse your stock one. That's about it. Pretty simple mod.
can someone please explain this to me? what is the advantage of changing t-stats... and is it a good idea in OK where it can get 110 in the summer...
Old 01-11-2011, 03:38 PM
916Timmy's Avatar
Rep:1443
I live in OKC and had the same question. Is it okay, with the proper fan setting in 110* weather?
Old 01-30-2011, 08:06 PM
old hot rod's Avatar
old hot rod old hot rod is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Rep:386
old hot rod is just really niceold hot rod is just really niceold hot rod is just really niceold hot rod is just really nice
Send a message via Yahoo to old hot rod
Thanks Gabrieldy and everybody else, just read this post, ran straight to O'Reilly's Auto Parts and they had part #4128 came home and its in. Thanks to y'alls help my performance upgrades are DONE.
Reps all around!!!!!
Hell Bent Steel Leveling kit, K & N filter, Tinted Windows,
Mufflex DOD18M, Mopar Intergrated Trailer Brake,
DiabloSport Predator (U7137) 180 Thermostat, WeatherTech Vent Visors
DiabloSport Catch Can (C-1040)
Old 01-30-2011, 08:26 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
no problem.
if you guys are still running the belt driven fan there is no need to change your elec fan settings. this helps with heatsoak even more if you live in really hot areas like OK.
Old 01-31-2011, 12:26 AM
916Timmy's Avatar
Rep:1443
Thanks man! I'll be getting one soon!
Old 01-31-2011, 08:51 PM
azrchrd azrchrd is offline
Vehicle: 2006 Ram 1500 Mega Cab 4X2
Color: Mineral gray metallic!
azrchrd is on a distinguished road
Ok, WTF? I installed a 180 t-stat two months ago, everything ran great until yesterday. I started the engine, let it idle for about 2 mins., then I get a check engine light? Luckily I have a friend with an OBD scanner, and it threw a code that said "coolant temp too low, 180 degrees"... Since that was the only code, and I had no other tell tale signs that I was having a cooling problem, I cleared the code with the scanner. Everything working fine right? Nope! Started my truck at work to come home, and wouldn't you know it I throw a code again! I'm going to check it again tomorrow at work, but I'm guessing its the same code. Any ideas? I plan on getting a DSP, and I know I'll be able to change the t-stat setting with it, but is there anything I can do in the meantime?
