180 T-stat option - Page 6 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 02-14-2011, 10:29 AM
JTHennessey JTHennessey is offline
Rep:60
JTHennessey will become famous soon enough
Originally Posted by azrchrd View Post
Ok, now I'm totally confused. When I started my truck this morning, the CEL disappeared? Drove to work (25 miles), still no CEL. When I started the truck to come home, still no CEL? Where did it go, and will it come back?
Its a setting in the truck... The CEL will trip if the truck doesn't warm up in a certain time frame. This is standard in the ECU and if the truck warms up in the set amount of time, your CEL will disappear.
2009 Dodge Ram 1500 Sport 2WD
- Lowered & Supercharged
Old 03-16-2011, 01:00 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Anyone have a pic of the thermostat housing opened up...I got the 4128 today and want to put it in with a "little" idea of what to do. I've swapped thermostats before, just want a little help
Old 03-16-2011, 02:05 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Dude its way simple i have pics but there on my home computer... Remove the 2 bolts then out with the old in with the new just use a flat head to help pry it out makes it little easier.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 03-16-2011, 03:19 PM
916Timmy's Avatar
Rep:1443
Thanks man!!! I thought it would be, just checkin!
Old 03-16-2011, 04:13 PM
RamTex's Avatar
Color: Stone White
Rep:366
Hey also you are gonna need to put about an inch more coolant in the tank cause you are gonna flow more.
Old 03-17-2011, 03:40 PM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
Heres a review I did on another forum.
http://www.**************/forums/sho...d.php?t=305529.
I ran my 180 stat all winter,it has been -37 degrees for almost 3 months off and on.
My truck has never thrown a code,but i use a Jet stat,which i know works the best.
The people who are throwing codes are probably Not using one.
Is there a differnce,well ask the people who keep getting codes.
If you tow or have hot weather the benifit is easy to see,with the reduced engine temperatures,and increase compression.
I do not use custom fan settings,but might once my tuner comes back.
I also tow with my truck daily,so I do notice a big difference in power with the 180 stat.
I would recommend this mod to anyone,regardless of how cold or hot it gets where you live.
Just check your evic numbers before and after you install it,and you will be amazed at the difference.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 03-17-2011, 09:11 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
glad you are liking your t-stat and it is working out so well. no codes for me too.
I am confused on how it increases compression b/c that's not really possible. Compression or compression ratio is calculated from the cylinder volume ratio at bottom dead center vs volume at top dead center.
example: a cylinder that displaces 1000cc at BDC and then 100cc at TDC would have a 10:1 CR.
Old 03-18-2011, 01:42 AM
williamhartle's Avatar
williamhartle williamhartle is offline
Vehicle: 2007 dodge ram
Trim Level: st
williamhartle is on a distinguished road
what exactly is the purpose of putting a 180 degree t-stat and is there any benefit in colder climates i live in fort mcmuray alberta?
2 inch leveling lift 3 inch body lift, 34" bfg mud terrain TA KM2, straight pipe, vararam intake, superchips cortex, Firestone air bags, skyjacker n8000 shocks rear, s8000 front struts, painted head lights, tinted tail,cab mount light, big shiny chrome balls.
Old 03-18-2011, 09:24 AM
Color: Mineral Gray
Rep:72
I think its oil pressure,not cyclinder pressure.
The 180 stat helps with towing and engine wear,so yes you could use it in Fort mac,but probably not so much in the winter.
I did use mine this winter,although its a bit cooler up there.
3:92 gears.
