Old 01-02-2011, 12:06 AM
cvfarm cvfarm is offline
Vehicle: 2001 Ram
cvfarm is on a distinguished road
Default Passenger Window Error
Well, so far so good with my '02 Ram, however I am having an issue with the passenger side [PS] window and/or switch. Sometimes the [PS] window switch will not operate the window up and down, but the [DS] will. It's kind of a hit and miss issue because it'll just randomly start working again. Say I jump out of the truck for a minute and get back in with the truck running... I'll have my passenger hit the up or down button to operate the [PS] window and it'll work. Then, we will drive down the road for 10 minutes and I will have 'em try the window again and then it'll magically stop working. Sometimes if I shut the truck off and then turn it back on it will start working again, it's just so very random. The [DS] switches work for all the windows though. What could be my issue?
Thanks for any replies.
Old 01-02-2011, 12:17 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Sounds like a switch. Might have some dirt or dust in it. I'd try a can of compressed air like used for a computer keyboard to give it a gentle cleaning before trying to tear it down and replacing the switch.
Old 01-02-2011, 12:52 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
^^^What he said^^^
Old 01-02-2011, 01:22 AM
Vehicle: 2001 Ram
Okay, I can try that. The switch itself feels strong and it clicks when pushed up and clicks when pushed down, but it could indeed be dusty or dirty.
Note: One thing I did notice just now was while driving at night that the lights on the driver window/door lock/mirror controls would dim on and off. When the lights would dim out completely on those switches I would simply push forward on the entire assembly a little bit and the lights would come back on. Is that a loose connection? Should the switch assembly/panel move at all?
The lights on the passenger window/door lock switch never had any issues.
Old 01-02-2011, 01:33 AM
jcasey10's Avatar
Rep:869
It could be a loose connection. You might try taking the door panel off and cleaning out the connections.
Old 01-02-2011, 11:20 AM
Vehicle: 2001 Ram
Does the door panel have to come off to get the window switches out?
Old 01-02-2011, 12:40 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
Yes, because they are held in from behind by a clip. You have no way of taking that clip off from the front without causing damage. Most likely your switch has rocked itself loose from the connector.
www.beatcraigslist.com - for posting dangers & secrets
