Fuel pump testing - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 01-02-2011, 12:09 PM
bplust bplust is offline
Vehicle: 1989 w250 diesel
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
bplust is on a distinguished road
Default Fuel pump testing
Hi all,
My buddy has a 1993 d150 318. The starter's fine and is turns the engine over well, but no fuel is getting to the engine. We can pour fuel down the throttle body (i might be using the wrong term here, I have very little experience working on gas engines), step on the gas, and it'll pop off briefly, and then starve for fuel.
I'm guessing that the fuel pump is shot, but I'd like to test it to make sure. What is the best way to make sure it's working or not?
Thanks,
Bryan
Old 01-02-2011, 09:03 PM
Jersey Devil's Avatar
Jersey Devil Jersey Devil is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Metalic Silver
Rep:50
Jersey Devil will become famous soon enough
Check your fuses first.
If fuse is ok under the hood on the fuel rail there will be a fitting that looks like a tire stem type fitting you will need to put a pressure Gage on it.
Its also you have a very badly clogged fuel filter you may want to check/ change that first.
Let me know how you make out.
