Old 01-02-2011, 01:31 PM
woken woken is offline
Vehicle: 2005 Dodge Ram 1500
woken is on a distinguished road
Default Popping Noise Earlier, Now truck Won't Move
New to the site and looking for a little guidance for a 2005 Ram 1500 4.7L 6-Speed manual trans. I backed out of parking spot last night and when pulling forward I heard a loud pop from the front passenger side like I hit something while going down the road. In reality, I was only going a few miles an hour, so I figured ice had fallen off the wheel well. I noticed no further problems continuing home, approximately a mile. Well, today it won't budge from it's parking space. Granted I'm sitting on gravel/mud/ice, but it's like the something is locked up with that wheel. 4wd engages and the steering has no issues side-to-side. Does this sound like a bearing or should I prepare for a worse prognosis?
Old 01-02-2011, 01:37 PM
It moved last night but won't move today? What is it doing when you put it in D? Or are you just frozen in place???? Give it some gas!!!
Old 01-02-2011, 01:45 PM
When I give it a little gas, my back wheels just spin.
Old 01-02-2011, 01:47 PM
Sounds like a bad prognosis but it may just be a locked brake caliper. I imagine you aren't in a warm climate but I'd suggest you pull the front wheel/tire and inspect your brake caliper and see if the pads are clamped onto the brake rotor.
If not, I suspect some mechanical issue inside the hub or differential has arisen.
Old 01-02-2011, 01:54 PM
Ok, thanks for the input. There's too much ice to jack it up, so it looks like I'll need to leave this one to the professionals.
Damn...sorry for your troubles. My input may be totally off as it's hard to diagnose from long distance. Good luck!
Old 01-02-2011, 02:09 PM
Your help is very much appreciated from any distance. And, it may very well be the solution. After applying the brakes hard a few times, it seems like it wants to go now. It's a make or break situation, so I'm going to let things warm up a bit around here, grab the tow company phone number and see what happens.
Old 01-02-2011, 02:16 PM
It's not unusual for brake calipers to stick, especially if they have gotten some ice or slush up in them and it freezes there.
Good luck!
