tonneaucovered.com
Old 01-02-2011, 06:50 PM
Agent 007 Orange's Avatar
Agent 007 Orange Agent 007 Orange is offline
Vehicle: 2007 DODGE RAM
Trim Level: SPORT
Color: BURNT ORANGE
Rep:74
Agent 007 Orange will become famous soon enough
Default 2007 Remote start question
Ok so I have an 07 and the remote start works great but it only stays on for 60seconds.....I know that the 08 trucks stay on for 15mins...anyone have any thoughts is something wrong with my truck or is it just the way it came from the factory????
[CENTER] [SIGPIC][/SIGPIC][/CENTER]
[CENTER][B][FONT=Comic Sans MS][COLOR=blue][FONT=Comic Sans MS][COLOR=blue][B]A Army soldier and Marine jarhead go to the head, take care of business and the soldier heads for the door when the jarhead says boot camp taught him to wash his hands afterward, the soldier replied boot camp taught him not to piss on his hands..[/B][/COLOR][/FONT][/COLOR][/FONT][/B][/CENTER]
Old 01-03-2011, 05:28 AM
Juice420's Avatar
Juice420 Juice420 is offline
Vehicle: 2010 RAM 1500 SLT C.C.
Color: Brilliant Black Pearlcoat
Rep:946
Juice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to behold
I found this in the manual for a 2010.
Press and release the REMOTE START button
on the RKE transmitter twice, within five seconds.
The parking lights will flash and the horn
will chirp twice (if programmed). Once the
vehicle has started, the engine will run for 15 minutes
So it looks like it's supposed to run for 15 minutes. Maybe call a dealer and ask if there's a way you can change the run time.
Justin
Black Mamba- Flowmaster 40 series, Airaid CAI, 20% tint, GTO taillight covers, ATA nerfs, AVS in-channel ventvisors, Curt hitch receiver, Extang Revolution Tonneau, EZ-down tailgate damper, Recon smoked 3rd brake light, Custom painted engine cover
Black Mamba's Thread
Old 01-03-2011, 05:22 PM
I push the skinny pedal
Rep:3308
Something must be wrong, they're supposed to run for 15 min.
Kurtis
Old 01-03-2011, 07:31 PM
Chili1K's Avatar
Chili1K Chili1K is offline
Trim Level: TRX4
Color: Email: Chili1k@att.net
Rep:1092
^^^ what they said!
Old 01-03-2011, 08:07 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Found this in the Owner's Manual on the Dodge site. http://www.dodge.com/en/owners/manuals/index.html
REMOTE STARTING SYSTEM — (GAS ENGINE
ONLY)
Your vehicle may be equipped with a remote starting
system, which will allow the vehicle to be started from
distances up to approximately 300 feet away from the
vehicle using the remote keyless entry key fob which is
part of your ignition key.
In order to remote start your vehicle, the hood, and all the
doors must be closed.
To remote start your vehicle, press the REMOTE START
button on the key fob twice within three seconds. To
indicate that the vehicle is about to start, the parking
lights will flash and the horn will sound briefly.
Once the vehicle has started, the engine will run for 15
minutes. To cancel remote start, press the REMOTE
START button once.
To enter the vehicle while the engine is running during a
remote start, you must first unlock the vehicle using the
UNLOCK button on the key fob. After the vehicle is
unlocked, you have 60 seconds to enter the vehicle, insert
the key in the Ignition and move it to the RUN position,
otherwise the engine will cancel remote start and automatically
turn off.
Remote start will also cancel if any of the following occur:
• If the engine stalls or RPM exceeds 2500
• Any engine warning lamps come on
• The hood is opened
• The hazard switch is pressed
• The transmission is moved out of park.
• The brake pedal is pressed.
The vehicle can be started remotely up to a maximum of
two times. The vehicle is also allowed a maximum of one
failed start, where the remote start sequence was initiated
but cancelled before the engine begins to crank. After
either of these conditions, or if the Vehicle Theft Alarm is
alarming, or if the PANIC button was pressed, the vehicle
must be reset by inserting a valid key into the ignition
and moving it to the RUN position, then back to LOCK.
The parking lamps will remain illuminated to indicate
that the vehicle has remote started and the engine is
running. The lamps will turn off when the ignition is
turned to RUN or the remote start is cancelled.
Brian:
Old 01-04-2011, 08:38 PM
Trim Level: SPORT
Color: BURNT ORANGE
Rep:74
Yea I figured it out....it was seriously operator error...I unlocked the doors after I started it haha..thank you everyone...
Next question, what wire do I need to use to hook up my factory SRT-10 truck push button start, yellow wire or the pinkish white one, I read on here somewhere that the wiring had changed between the 05-06-07 years and if I get it wrong then I will blow the fuse to my gauges...anyone care to clarify for me PPPLLLLLLEEEEEEAAAAASSSSEEEEEE
