Old 12-19-2010, 10:52 AM
Night.Runner Night.Runner is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Big Horn
Night.Runner is on a distinguished road
Default A/C heat defrost is all jacked up
Just got my 2006 ram yesterday and I love it, however last night my windows iced over and I found out only the passenger side defrost works...after noticing this I relized that the ac and heat hardly put out air when on full speed. They get hot and cold just don't put out much out of the vents. Any ideas what this could be? Also is this a usual problem for the trucks?
"That thing got a HEMI?" "Your bout to find out!"
Old 12-19-2010, 11:29 AM
Rep:1845
I'll bet my hat you have a broken recirc door. Remove the glove box and with the key on, change the settings from fresh air to recirculate. If you don't see the door moving, you've found your problem.
Old 01-01-2011, 12:25 PM
Just opened the glove box, dont see anything moving when i switch from recirc to outside.. where would the door be? and how would i fix it if that is the problem?
Old 01-01-2011, 02:00 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
You can buy a replacement door at the dealership, my 2003 came with a door, new box, new motor as a unit. you can install the unit or pull the new door out and use it. Either way, it is a heck of a job.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 01-01-2011, 02:13 PM
RootBeer RootBeer is offline
Color: RootBeer
Rep:1287
Did you "open" or "remove" the glove box? It needs to be removed.
Brian:
Old 01-01-2011, 06:34 PM
I removed the glovebox, couldn't see the door because it wasn't there haha broke off, Took it out from underneath. Pretty easy fix, don't have the recirculate option anymore but everything else works perfect now
a/c, a/c problems, defrost, one side
