6" pro comp lift with 37's ? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-02-2011, 11:25 PM
manitoba2010ram manitoba2010ram is offline
manitoba2010ram is on a distinguished road
Default 6" pro comp lift with 37's ?
I have a 2010 quad cab sport and I will be installing the 6" procomp lift. The local dealership is installing these lifts with 18" rims and 35's. So in the spirit of trying to be different I'm looking at procomp 7047 series wheels 20x9 with 5.25 backspacing and would like to install 37" tires. Problem I'm having is that lift call a max tire size of 37 12.5 and these are not easy to find in a 20. Has any one ran a 37 13.5 20 with my backspacing and not had any normal driving rubbing?
Old 01-03-2011, 11:55 PM
come on somebody knows
Old 01-04-2011, 12:52 AM
ACE778's Avatar
ACE778 ACE778 is offline
Vehicle: 2010 RAM 4X4
Trim Level: LARAMIE
ACE778 is on a distinguished road
I am looking for a similar lift and tire set up. Im sure someone has done this and a few people should know the answer. Try posting the question in the lifting section.
Old 01-04-2011, 01:03 AM
iRESQu iRESQu is offline
Rep:2217
I had a 6" ProComp with 37x13.5 on 17's and rubbed slightly. I had to cut away some of the inner fender well to avoid the rubbing. I don't know if that helps at all, but that is the best I can offer.
Old 01-04-2011, 02:52 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
damn that truck is sexy i donno why you got rid of it
Old 01-04-2011, 02:55 PM
Rep:1625
Don't worry, it's "still in the family"
Old 01-04-2011, 03:08 PM
Rep:3347
You could always try a 1/4" spacer, or go to an adapter and move them out a lot more.
Incest?
Old 01-04-2011, 06:22 PM
Rep:2217
I have growing girls with miles of legs and the QC wasn't enough. Now, if they get any bigger, then they can deal with it or walk.
Thanks Bud! And the new owners, Dodgeman70592 and his wife mySRT8u, are loving it!
Old 01-04-2011, 11:06 PM
tbeaton tbeaton is offline
Vehicle: 11 2500 4x4
Rep:14
tbeaton is on a distinguished road
the super swamper vortrac comes in a 12.5. bfg offers it in the at and km2. yokohama has them in both mt and at. as long as your not looking for e rated tires you should have no problems finding them.
11 deep water blue 2500 big horn, 5.7 hemi, 4.10 gears, 6" bds short arm lift, 20x9 -12 offset kmc hoss black wheels, 37x12.5x20 nitto trails, n fab cab length nerf bars, banks muffler w/ lou's custom tubing, pocket flares, top gun customz dual steering stabilizer, mission sled deck.
Old 01-07-2011, 03:49 PM
CHADDER03's Avatar
CHADDER03 CHADDER03 is offline
Vehicle: 2009 Ram Quad Cab
Rep:29
CHADDER03 is on a distinguished road
I just went through all of this. it was brutal i spent a couple days at the parts store with the guy trying to figure out how this was going to work and what was instock. to run 37x13.5 your best to go with a 20in wheel with at the very most a 5in backspace. now that all depends on whether the tire is actually 13.5, i found a lot of them if you look at the specs are closer to 14. i personally went with super swamper m16's 37x13.5r20 and the wheels have a 4.5in back space and a -12 offset. the way the tires stick out looks awesome its not to far but not sucked in to much. the only rubbing issue i had was the plastic stone gaurd on the driver side rocker panel rubbed a bit so i trimmed it back a bit. the only time it rubbed was when the wheel was turned half way i was braking and pulling into a store with a roadside curb. so not really a big deal but still an issue. what ever you do dont go with 35's. i find they just look way to small, even the 37's dont look that big on there. as far as the lifts go i went with the skyjacker and the guy who install it was extremely impressed, even the alignment was barely out after. it keeps all factory geometery and the ride height is level where as a lot of lifts still leave the front sagged down. i did a hell of a lot of research on the lifts and it came down to procomp superlift and skyjacker. all seemed to be in close quality but in the end personally the skyjacker won hands down.
hope that helps
