Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 01-03-2011, 01:27 PM
Silverspyder247 Silverspyder247 is offline
Vehicle: 2003 Dodge Ram 1500 Quad Cab
Rep:79
Silverspyder247 will become famous soon enough
Default LED Cup Holder Lights
I've been reading on the forum for a couple months now and have used some things I've found on here to do a couple mods on my truck and would like to give back a little bit.
I have a flip-down cup holder on the front instrument panel but no lights and finally decided to do something to make it easier to find my refreshing beverage at night. (Sorry, I didn't think right away to take pictures step-by-step... I think I have enough to get the idea across though.)
I took off my dash and unscrewed the cup holder mount. That was the easy part. I already had 5mm LED's and holders and because I'm cheap, that's what I used. I had to then figure out where I wanted to put the LED's so they would properly light up the correct area and not get in the way. Finally I figured out I was going to mount them towards the front of the cup holder in the portion that angled forward towards the dash.
As you can see, I decided to put in 2 LED's for each side of the cup holder. I should have taken a little more time and marked the position of the holes before I started drilling. You can see that they don't quite line up... In the next picture you'll be able to see why this was a little stupid but in the end works out for me anyways. Now I popped off the front panel of the cup holder and realized I should have done that first...
You can see the arms that control the size of the cup holder will smash into the LED closest to them. Eventually I'm sure that will break the LED but for me, my cup fits perfectly without shrinking the size. Now you can see all my wiring and LED's are installed on the cup holder.
On the backside of the cup holder assembly (side closest to the front of the truck), you can see my wires sticking out. Be sure you leave a bit of slack in the wires for the opening and closing of the cup holder.
Now I needed a way to get power to the LED's. Cigar lighter happened to be the closest thing and, conveniently, is only powered while the keys are in the ignition. I spliced into that connector.
Well it was nice to have the lights automatically come on but I wanted to be able to flip them off when I didn't need them (Plus I plan on adding more LED's elsewhere) so now I needed to find a place for a switch. The open spot below the vent on center passenger side was perfect. In went the switch.
And of course the reassembly of the dash and cup holder installed.
And with the cup holder down.
Please excuse the mess... It was raining and I didn't feel like cleaning in the cold rain...
And finally pictures with the lights on. Sorry, don't have any taken at night yet...
And a closeup with them on.
I don't know if I missed anything but that's about all I have on this little mod. I need to do a little cleaning and then get some pictures in the dark because I'm sure you would like to see those as well.
File Type: jpg LED's Installed in Cup Holder 3 (Large).jpg (104.0 KB, 313 views)
File Type: jpg Dash Installed Cup Holder Up (Large).JPG (97.9 KB, 312 views)
File Type: jpg Dash Installed Cup Holder Down (Large).JPG (109.2 KB, 313 views)
File Type: jpg Cup Holder Installed Lights On 1 (Large).JPG (103.7 KB, 319 views)
File Type: jpg Cup Holder Installed Lights On 2 (Large).JPG (75.7 KB, 316 views)
Old 01-03-2011, 01:42 PM
Rep:3337
A nice mod there. I know I have trouble finding the cupholder in the dark and this is a simple enough mod to do.
Old 01-03-2011, 05:47 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Welcome to the site, nice mod
Old 01-03-2011, 06:01 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
thats a pretty sweet mod there bud now you just gotta get night time pics
Old 01-03-2011, 07:24 PM
Chili1K's Avatar
Chili1K Chili1K is offline
Trim Level: TRX4
Color: Email: Chili1k@att.net
Rep:1092
Cool mod.
Did you think about flush mounting them above the cupholders? A pressure switch when you close the door they will go out? Just curious, because when they are on they are aimed upward. not sure how bright they are at night.
Looks good!
Old 01-03-2011, 08:09 PM
Rep:79
Lightbulb Night Shots
Here are the night shots of the cup holder.
@Chili1K
I thought about mounting them above but I would have needed different LED's and I already had these on hand. They are way too bulking to fit in the small space above the cup holders. How I have it wired right now works for me, if I do forget to turn the switch off, as soon as I remove my keys from the ignition, power is cut from the circuit.
And with the rest of my interior lights on:
Old 01-03-2011, 08:14 PM
Rep:3337
Nicely done, and I love the interior lighting
Chili1K's Avatar
Trim Level: TRX4
Rep:1092
cool pics.. I was worried about the light in the eyes..Thanks for the updates!
Old 01-03-2011, 08:26 PM
Rep:79
Oh yeah, I have about 8 feet of LED strips in the footwell area that are also red. They are hooked into the same circuit as my dome light so they come on when the door opens or I turn on the interior light. As a bonus they fade off like the stock dome light.
I had that idea from another post in the forum from a user who was doing puddle lights.
http://www.ramforumz.com/showthread.php?t=56927
Old 01-03-2011, 08:30 PM
Rep:3337
Did you wire them directly into the dome light line or did you use a relay? I have a relay on mine and when it begins to dim, the relay begins to buzz due to the low voltage. I wasn't sure if the stock line would handle all the LEDs I have on it (about 20' of LED SMD strip), but if you've got that many then I could probably get away with it.
