Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-03-2011, 05:59 PM
toddrod's Avatar
toddrod toddrod is offline
Vehicle: 2001 Dodge Ram
Color: Yellow
Rep:55
toddrod will become famous soon enough
Default what's normal operating temperature?
Hey all, if you've been following me I just changed my water pump, thermostat, radiator, hoses and coolant. The temperature gauge needle is sitting right exactly between 55-100 (so about 75ish). I don't remember where it was sitting before I changed the system. Does that sound like a normal operating temperature?
Old 01-03-2011, 06:11 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
I don't think so. I beleive the normal temperature is much higher, something like 200+ F. It will depend on the thermostat setting among other things. My guess is your gauge is off or I am really off!!! Think about how hot your anti-freeze gets - I doubt it is 55 when the truck has been running for a period of time.
Old 01-03-2011, 06:12 PM
Rep:147
I should have asked - is your reading in C or F?
Old 01-03-2011, 06:15 PM
Tornado39647 Tornado39647 is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: SLE Sport
Tornado39647 is on a distinguished road
What temperature thermostat did you place in the truck? The gauge should read the temperature that the thermostat is for at normal operating temp. The water in the motor should reach the thermostat temp before the water will start flowing threw the block and back into the radiator. The reason for the thermostat is to maintain and control the operating temp of the motor for fuel economy and performance. Hope this helps. Should be 180 degree or 210 degree depending what you bought.
Old 01-03-2011, 06:17 PM
yes that is true if it is 75c then that is 167f.
Old 01-08-2011, 01:44 AM
toddrod's Avatar
Color: Yellow
Rep:55
Hey guys the thermostat I installed is a 192f.
Old 01-24-2011, 03:27 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Mine sits around 205-210F. Thats after I re-vamped the whole cooling system. I am using a 195F t-stat.
