Old 09-27-2010, 08:43 PM
bqram99 bqram99 is offline
Vehicle: 1999 Dodge Ram
Trim Level: Sport 2wd
bqram99 is on a distinguished road
Question spacer lift gone wrong
I installed a 2 inch rough country spacer kit on my 2nd gen. and now my upper ball joint is touching the frame where my bump stop mounts up. I am about to tear it down. Any suggestions?
Old 09-27-2010, 08:52 PM
Okiespaniels's Avatar
Trim Level: Fleet
Rep:47
2 questions...
2wd, right?
And you followed the directions?
Old 09-28-2010, 01:39 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
uh oh thats no good i hope u get er fixed up soon...good luck
Old 09-28-2010, 01:41 AM
ugh...that sucks. There's no clearance at all?
Old 09-28-2010, 02:38 AM
yea sorry I didn't specify earlier 2wd and I work in a shop so yes I am capable of the work. I ended up taking it off, I had it all in right I am sure. What I don't know is if there is a difference between the control arms of a sport and regular package, or if it had leveling coils on it already. Replacement shocks are the same size so I don't know. I did measure the coils and they measure 13 & 3/4 of an inch, but I have not found the specs for stock springs so I still don't know why exactly it didn't work, but I will find out. I had no clearance man my upper ball was resting on that bump stop bracket in fact it burred up the nut on the passenger side and I had to clean it up.
Old 09-28-2010, 08:20 PM
autodoorman autodoorman is offline
autodoorman is on a distinguished road
I just installed a rough country 2" lift on my 01 ram 1500 2 wheel drive, and it raised my front end 3 3/4" . Any thoughts on that?
Old 09-28-2010, 08:42 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
My thought is you got more bang for the buck!
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 09-28-2010, 08:55 PM
are your ball joints touching the bump stop bracket at any given time?
Old 09-28-2010, 10:45 PM
Nothing is hitting ,The ride is a lot stiffer than i expected, I have 17" rim's with 245/70/17 tires. Before the lift it measured 34" from ground to bottom center of front fender, after the lift it was 37 3/4 . I also used 2" block and U bolts on the rear. Purchased the lift through Addrenaline Motorsports, they said i probably have stiffer springs than most, the truck sits level and looks good now, but I'm afraid it may sit to low in the rear when i pull a trailer. I may try 1" spacers to see if i can get 2" of lift that way.
Old 01-20-2011, 02:49 PM
97 5.9 MAG's Avatar
97 5.9 MAG 97 5.9 MAG is offline
Vehicle: 1997 Ram 1500 2wd ext cab 5.9
97 5.9 MAG is on a distinguished road
Autodoorman do you have any pics of your truck im looking to do a smilar lift on mine
spacer lift
