Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 01-03-2011, 11:59 PM
eye4mud eye4mud is offline
Vehicle: 1999 Dodge Ram 3500
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
eye4mud is on a distinguished road
Default Engine surging while holding at a constant speed need help!
I have a 19999 Dodge Ram 3500 Dually 5.9l Diesel. The engine is stock no mods, all factory original intake and exhaust with an exhaust brake.
First my cruise control stopped working and now while trying to hold a constant speed I get intermittant surging, the engine will drop in rpm's and and then surge back above where it was before and then return to the speed I was holding it at. Originally only did this at lower speeds, now is becoming more frequent at higher speeds.
Any ideas? I am new to Diesel's so I am lost... EGR Valve? Throttle position sensor bad? Fuel filter clogged?
Any help would be appreciated.
Old 01-04-2011, 12:43 PM
I push the skinny pedal
Rep:3277
I would look at the fuel system first, it's the most likely cause of the surging. If it's getting progressively worse, then the fuel filter is most likely gumming up and it's not flowing as much fuel any more. You can change out the fuel filter and see how that goes. If you want to make a real difference, you could also install a FASS or Snow fuel separator system to improve the fuel going into the chambers.
Kurtis
Old 02-10-2011, 12:30 PM
wbodine's Avatar
wbodine wbodine is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Outdoorsman
Color: Green & Gray
wbodine is on a distinguished road
Either one of two things the APPS switch or the VP-44. Sorry no good news. Still check the fuel filter first. Of the two I would guess the APPS. I have a good source for them the Dodge house gets $400 for them...
Bodine
Old 03-18-2011, 03:27 AM
DieselD24 DieselD24 is offline
Vehicle: 2001 Dodge Ram
DieselD24 is on a distinguished road
I had the same exact symptoms. Cycle the ignition on and off three times and look at your odometer display. You should get either of the following codes. P1693, P0121, 0122, or P0123. If you get any of the following codes, it is a defective APPS. Local parts store has them for $300, I know of a site that has em' for $160. If you need one, let me know.
Good luck.
Old 06-15-2011, 04:55 PM
kenaustin9 kenaustin9 is offline
Vehicle: 2001 ram 2500 quad cummins
Color: Garnet Red
kenaustin9 is on a distinguished road
I did the code check and got P PCU, P1602, P1693. So the 1602 means a APPS switch. I would appreciate your source info.
Thanks,
Kenaustin9
Old 06-17-2011, 06:30 PM
Google Timbo Apps. He sells them for $160 online.
Old 06-17-2011, 06:37 PM
Any by the way, there isn't a 1602 DTC stored in the 24 valve Cummins. There is however, a 1693, and what that means is when you get a 1693 it's usually a companion code stored in the PCM. So, you will have 1693 along with another code, but 1602 is not a 24V code. APPS codes as state before are 0121, 0122, and 0123. If you get either one, time for new APPS.
Old 06-24-2011, 05:11 PM
Color: Garnet Red
Default APPS and codes
"Any by the way, there isn't a 1602 DTC stored in the 24 valve Cummins. There is however, a 1693, and what that means is when you get a 1693 it's usually a companion code stored in the PCM. So, you will have 1693 along with another code, but 1602 is not a 24V code. APPS codes as state before are 0121, 0122, and 0123. If you get either one, time for new APPS."
I rechecked, and I must have read the code without my glasses or something. the codes are:
P1682 and P1693. Do you know what the P1682 indicates?
The code references are causing me to scratch my head a bit. I haven't been able to find code lists on the forum, or much about retrieving them, where they are stored, or companion codes stored in the PCM, etc. Is there a reference around that explains all that stuff?
Regarding the companion code, does it mean I need to get a code reader to find what is in the PCM?
Thanks for your patience. I suspect that the APPS is the issue from reading other threads about these symptoms, but it would be nice to know what the codes show before I order a new one. I'll check out "Timbo APPS". Thanks for the response.
Ken
Old 06-28-2011, 08:51 PM
wbodine's Avatar
Color: Green & Gray
Timbo APPS this is good stuff...
Bodine
