Old 01-04-2011, 01:28 AM
bkirchner bkirchner is offline
Vehicle: 2002 ram 1500 4x4 4d 8 ft bed
bkirchner is on a distinguished road
Default Ballast resistor in 02?
2002 Ram 1500 4.7. Truck sat for a week or two, would not crank- common for this truck, has always done this. This time, jumped it, dies as soon as you let go of the key- exactly like the old MOPAR ballast resistor issue. Didn't see one under the hood, figured they wouldn't actually still use those things,.... anyway, before I brave the 20 degree weather to get into it, anything obvious on these trucks?
Old 01-04-2011, 12:51 PM
I push the skinny pedal
Rep:3277
How's the condition of the battery, and have you had the alternator tested as well? If the alternator isn't putting out then it'd die right away.
Kurtis
Old 01-05-2011, 09:47 AM
Thanks for the post, CdnoilRAM, - Battery and alt are good, my draining problem is from aftermarket junk sucking on the battery. As far as the running problem, I braved the cold and started in on it. First thing I did was disconnect the battery for a couple of minutes to rule out glitchy sparks, and that's what did it. Works fine now. Just like fixing a pc!
