2011 4x4 Front wheels won't properly - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 01-04-2011, 01:06 PM
papasmurfor9 papasmurfor9 is offline
Vehicle: 2011 Dodge Ram Laramie 4x4
papasmurfor9 is on a distinguished road
Default 2011 4x4 Front wheels won't properly
I have a new 2011 Laramie 4x4. When I am in 4H or 4L the front wheels will not pull hard enough to spin the front tires. The back will spin like crazy but the front barely pull. Is this common or do I have a problem. It severley limits offroad capability. Please help.
Old 01-04-2011, 01:45 PM
Rep:3347
I can't say I've seen too many front tires spinning like the rears on many trucks. I wonder if the transfer case has something to do with it, but I'll wait for some others to chime in and see what they say.
Old 01-07-2011, 10:42 PM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1260
Its the gearing. 4wd Hi (lock) on 4th gens is 30-70. 30% power to the front, 70% to the rear. move it over to 4Low, and it goes to 50-50. a stock 4wd gen 4 will spin the front tires, mine does it all the time, but you have to mash it, and turn off the ESP. If you dont turn off the ESP it will not spin the tires AT ALL.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 01-10-2011, 06:25 PM
Mine will not spin the front tires in 4HI or 4LO. It really sucks for off road use like this. I think i must have a problem. I can tell they are pulling a little but not much. Surely Dodge did not design them like this. I can't go thru anything, much less pull something off road. If I put the hammer down if 4hi or 4lo i want all four tires pulling and slinging mud, etc. Otherwise i have wasted my money on this truck. I'm pissed about it. Going to dealer asap.
Old 01-11-2011, 11:26 AM
Butter's Avatar
Butter Butter is offline
Vehicle: Ford owner as of 4-25-15
Trim Level: XLT
Color: Flame Blue Metallic
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
When I turn the traction control off in 4H mine will spin when I get on it, the traction control automatically turns off when I switch to 4L and they spin as much as the rear. If it's not working like that I would say you need to speak with your dealer.
Does your truck have and AWD option? If your accidentally switching to AWD this would explain your problem.
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 01-11-2011, 11:29 AM
Resident Technician
Rep:1915
Which transfer case do you have?
Old 01-11-2011, 02:31 PM
I have the AWD option. It will not spin even if I turn the esp off. I am going to take it by the dealer asap.
Old 01-11-2011, 02:37 PM
Resident Technician
Rep:1915
What you're experiencing sounds like normal operation for the BW 44-44 case. What about in the 4 Lock position? The following is the operation description directly from Chrysler.
OPERATION
Depending on traction conditions, the DTCM will modulate the electromagnetic clutch assembly to vary the amount of torque applied to the front axle. Torque is transmitted through the input shaft to the clutch and drive sprocket assembly, and is transferred directly to the rear propeller shaft, and to the output shaft and front propeller shaft by the drive chain. The oil pump circulates gear lube throughout the case to provide clutch cooling.
Old 01-12-2011, 04:15 PM
OK. I went to the dealer today and they said the clutches are gone in the transfer case. That is why the front tires are not pulling. We lifted the truck and were able to hold the front tires and keep them from turning while in 4x4 mode. That is how little they are pulling. They are going to replace the clutches and DTCM. They could not explain why it happened. It showed an overheat code, but no reason why. I have not done anything to abuse the transfer case and as best I can remember it was like this from day one. It now has 11K miles on it. He did say that they were having a hard time locating the fluid it calls for and that it is conceivable that the wrong transfer case fluid was put it at the factory causing the clutches to fail. This is only speculation right now, but they will be able to tell after they tear into it. Also, there is a recall on the rear axles on 2011 Rams. They need additive to prevent overheating.
Old 01-12-2011, 04:20 PM
Resident Technician
Rep:1915
That's pretty bizzare; I've never seen a failure with those cases. The recall you speak of is for some of the diffs that weren't completely filled and the additive is for the clutches in the LSD models, not for cooling.
