Old 10-02-2010, 02:17 PM
mark09sport mark09sport is offline
Vehicle: 2014 Ram RC SB
Color: Blue streak pearl
Rep:18
mark09sport is on a distinguished road
Default Any HP gains with mufflex?
Looking at replacing the stock sport muffler with a mufflex magnaflow.
Any HP gains with the straight thru magnaflow?
The stock dual exhaust on the sport seems to flow pretty well.
2014 Ram Express 4x4 Reg cab Short bed 5.7, 8spd, 3.92 gears, Blue streak pearl with all options. 180 T stat, drop in, wrapped intake tube, 24" Mufflex, 2 1/2 lift, Black out ram emblems, Tail light tints.
More MODS to come!
Old 01-01-2011, 06:24 PM
old hot rod's Avatar
old hot rod old hot rod is offline
Rep:386
old hot rod is just really niceold hot rod is just really niceold hot rod is just really niceold hot rod is just really nice
Send a message via Yahoo to old hot rod
stock exhaust is not a free flowing system, but when i got my mufflex 18 i could see all the way thru it so it has to be a free flowing system and that should help HP , and it sounds great
Hell Bent Steel Leveling kit, K & N filter, Tinted Windows,
Mufflex DOD18M, Mopar Intergrated Trailer Brake,
DiabloSport Predator (U7137) 180 Thermostat, WeatherTech Vent Visors
DiabloSport Catch Can (C-1040)
Old 01-01-2011, 06:37 PM
I'm sure there are dyno measurements to view but given differences in DA, temp, etc...your results will vary and differ from the mfgr's claims.
To realize full potential of an exhaust that flows more air you need more air in. The internal combustion engine is just a big air pump. More air in + more air out = More Power.
I'd suggest you consider doing intake & exhaust to realize the maximum potential offered by either mod.
Old 01-01-2011, 08:15 PM
BigOrange BigOrange is offline
Vehicle: 2013 RAM 1500
Trim Level: EXPRESS QUAD CAB
Color: BRIGHT SILVER
Rep:17
BigOrange is on a distinguished road
^^^ +1 on the intake & exhaust working together to free up some Hp's. The y-pipe mod is another restrictive area that, when fixed, provides a bit more power as well as some sound enhancement.
Magnaflow 14" SI/DO, No Resonators, K&N Drop-In Filter, De-badged.
Old 01-03-2011, 01:38 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Check this thread out
http://ramforumz.com/showthread.php?t=69215
Great info and pics of the Y-pipe. Do these together with an intake to make the most gain!
Old 01-04-2011, 01:25 PM
joey0480 joey0480 is offline
Trim Level: Crew Cab Sport 4x4
Color: Brilliant White
joey0480 is on a distinguished road
I don't believe you are going to see much, if any, change from a muffler alone. You need to do the y-pipe and/or heads to see anything around there.
Sylvania 9145ST, H11ST, and 9005ST, Cortex 3950, K&N filter, Magnaflow 12198 and Y-pipe 10778
Old 01-04-2011, 04:02 PM
chad3113 chad3113 is offline
Vehicle: 2013 Dodge Ram 1500
chad3113 is on a distinguished road
WOW, just crawled under my truck (2010) to check out the y-pipe... that thing really is terrible! I was going to get the 18'' magnaflow put on tom, and i'll have my shop install the magnaflow y-pipe while I'm at it.
I'm new to the "Hemi", but I've been a mustang guy for years now, and I can tell you that a restriction in exhaust like the rams stock Y, would net a good 3-4 rwhp on a DOHC mustang.
Better comparison to the Hemi (345) would be the LS1 (347) since the fbody platform (camaro/transam) also use a y-pipe configuration and single muffler.
Those cars pick up around 10-13rwhp with a Y and catback.
Keep in mind that these "assumptions" are all based on a dynojet at sea level...
Old 01-04-2011, 04:04 PM
Exactly. The Y-pipes on here are horrendous. I am actually getting my y-pipe and 14 inch magnaflow put on Friday. I was going to go with the muffler first till I read around and looked at the y-pipe....disheartening.....
Old 01-04-2011, 04:31 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
The Y may be ugly but you would be surprised as to what it will flow. As for gaining HP, I can gain 10-20 HP on a dyno just by icing my S/C, so I think sometimes people put to much stock in dyno numbers. The tuner can do what he wants with your numbers...plus I don't care about HP when at the track as much as I care about hooking and having the truck set up right. I have beat many SRT10 trucks cause their biggest issue is they cant get traction. TQ is where it's at boys....
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
