Old 01-11-2011, 08:23 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
YIKES!!!!
That is definately not right! I know you said your lower arms are stock, but does anyone know if the procomp lifts use different hubs/spindles? Because what I am seeing is that the spindle (hub) is contacting the control arm. Bad Juju.
Its possible that whoever installed the lift, did so improperly, without adjusting your steering. Is it that way on the other side? If not, thats what it was. As far as altering that hub, feel free, it wont hurt anything. But it isnt going to solve your problem, Your rack is out of adjustment, more than likely the inner rods (inside the rack and pinion) need to be adjusted. Take it to a lift shop and have the steering rake adjusted, otherwise you are going to break a control arm. I would replace those arms too. Thats yucky.
Did you buy the truck with the lift? Or was it like that when you bought it. Do you know the shop that did the install? If so I would be on their doorstep in the morning. ANY serious hit from a rut or hole that the truck could normally take, will snap that control arm, its weakened right at a crucial point.
Hope this helps.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-30k miles-BF Goodrich Rugged Terrain T/A, Mufflex Muffler Delete, Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist, Total Load Control, AVS Visors and Bug Shield, K&N Drop-In, XenonDepot 5000k LED Headlamps in factory projectors.
Old 01-20-2011, 12:14 AM
lifted03HEMI's Avatar
lifted03HEMI lifted03HEMI is offline
Vehicle: 2003 Dodge Ram
Trim Level: Laramie 4X4
Color: Midnight Blue
Rep:19
lifted03HEMI is on a distinguished road
I have an 03 1500 4X4 with a 6" BDS lift and 35X12.50R20 tires and my turning radius was really effected when I put all this on as well.
Old 01-25-2011, 06:31 PM
strafen's Avatar
strafen strafen is offline
Vehicle: "Beast" - '09 Ram 1500 4x4
Trim Level: Laramie - Crew
Color: Inferno Red Crystal / Lgt. Greystone
Rep:42
strafen is on a distinguished road
thats a SAWEEEET lookin truck you got yourself there..... sorry to hear bout the control arm issue... hope you get it fixed right and get to enjoy that great ride.
btw. CC? colorado city by chance?
X'd seatbelt minder, 13" radio antenna - black, more to come.
Old 02-09-2011, 10:27 AM
337ram 337ram is offline
Vehicle: 2009 1500 4x4
Color: grey
Rep:15
337ram is on a distinguished road
I have the same lift as you with same brand as rims , just went and looked at mine and I have the samething happing to mine!!!!!!
Old 02-09-2011, 10:32 AM
Color: grey
Rep:15
Maybe both of us should contact procomp and send in pics , two trucks the same with the same problem in differnet states , something is not right, I am leaning more towards our rims , offset and spacer tho then a procomp problem!I am leaning towards a bigger spacer , I beleave my spacer is 1/2" and im sure I could get 3/4" spacers and that might put it far enough away that it doesnt contact. Thats makes another issue, I like using the smallest spacer I can! need inputs
Old 02-09-2011, 10:37 AM
Color: grey
Rep:15
Looking on there site (PC) it said our lifts come with bump stops, my bro in law actually works for a 4x4 lift shop going to take it to them and see what they say
Old 02-09-2011, 09:07 PM
Color: grey
Rep:15
Was at work today thinking about this issue , it has nothing to do with the offset , duh lol! It could be how the travel was setup , but im curious if any of the stock 4x4s are doing the samething , can someone that has a stock 4x4 look and see if your spindel is digging into your arm also??
Old 02-12-2011, 01:31 PM
Poriggity Poriggity is offline
Vehicle: 2004.5 Dodge Ram
Color: Molten Red/ Silver
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Rep:93
Poriggity will become famous soon enough
I would definetly contact pro comp on this one, and get that A Arm replaced. I'd go as far as to not drive the truck in that kind of shape. Pro comp needs to do something about that.
Scott
2004.5 2500 Quad Cab LB 4x4 with stuff.
Old 02-13-2011, 11:30 PM
Color: grey
Rep:15
Emailed them with this thread ,im hoping they do something instead of saying installer error, can someone pm pigzfly and tell him to come back to this post , I want him to email them also ,I cant pm , still a noob and it wont let
Old 02-13-2011, 11:52 PM
Rep:1625
I know you can't PM yet, but can't you write on his profile page?
