Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Body & Interior
Body & Interior 1st Gen Dodge Ram Body & Interior Problems and Questions.
Old 01-04-2011, 05:32 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
Default Shifter Knob
Does anyone know how the factory shifter knob is held in place on a 2008 Ram 1500 ? Can't seem to get it loose and I don't want to mess up the threads if there are any.
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 01-04-2011, 05:58 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
don't know if the 08, is the same as the 09, if it is, you need to gently pry the plastic chrome piece under the black knob straight down till it releases, a thin flat tool like a putty scraper helps, then you gently pry the knob fingers that extend down onto the shaft, away from the shaft while pulling straight up on the knob..it will snap off....There is a very small tab located on the consel, about 1/2 inch or less in size...if you pop of this cover, and depress the red tab under it, you can move the shifter into "N" position, which will make the whole thing easier...there are some other posts with photos on this forum site, you may want to look at...hope this may help
So it is written ! So it shall be done!
Old 01-05-2011, 12:13 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
manual tranny? you pop up the shifter indicator and remove the nut, unthread the knob...
Old 01-12-2011, 06:11 PM
sk8noregon's Avatar
Rep:637
Great, thanks !
