Much cooler air on driver's side! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 01-04-2011, 09:46 PM
Thetolleyman Thetolleyman is offline
Vehicle: 2003 Ram 1500 Quad Cab
Color: Gold/Silver
Thetolleyman is on a distinguished road
Default Much cooler air on driver's side!
Since winter set in I notice the drivers side air not getting as warm as the passenger side air. I also had the common mode doors issue too. So, I purchased Mode 1,2, and blend doors and promptly installed all of them. It took care of the no floor air issue, but I still have much colder air in the drivers side?
Advice?
Could the recirc door do this?
How about the lower mode two door, seems to me there is a door below the heater core too?
PS: I flushed out the heater core real well too, didn't seem to be an issue really.
[03' Ram, K&N FIPK, Electric fan conversion, Fast Man TB, Superchips tuner, Magnaflow cat-back, 08' intake, 1" body lift, 1.5" coil spacers, 3" lift spindles, 1 1/2" block on rear, rear leaf flip,. [/SIZE]
Old 01-05-2011, 09:58 AM
Resident Technician
Rep:1915
That's normal to a point. How much cooler is the air on the drivers side?
Old 01-05-2011, 06:03 PM
Color: Gold/Silver
Its significantly different. I haven't measured but the passenger side gets hot enough you don't want if blowing on you, while the drivers is still too cool, you wouldn't want it blowing on you either, I'm going to guess a 50-60 degree difference.
Old 01-07-2011, 05:37 PM
Color: Gold/Silver
Heater Treeter answered my inquiry into this, suggesting an "aggressive" flush of the core. I followed there advice, and now have good heat. I'd say the temperature difference is less than 10 degrees now.
Old 01-08-2011, 04:31 PM
claybar claybar is offline
Vehicle: 2003 Dodge Ram 1500
claybar is on a distinguished road
I flushed my radiator and ran water both ways through the heater core and had good heat for 2 or 3 days......now my heater is blowing out luke warm air on both sides.....it was blowing cool air on drivers side and hot air on passenger side.....that's why I flushed everything and replaced the thermostat! Also, has anyone replaced the funky drain cock that is in these radiators! Mine is leaking a little, after doing the work on the truck. The low heat in the heating system is not from low coolant.
Help!
Old 01-15-2011, 11:53 AM
Color: Gold/Silver
Would there be any issue with swapping the heater core hoses. This should reverse the flow thru the core. I'm thinking that if the core is prone to cooling from one side to the other as the air blows over it, thus causing one side of the heat to be cooler (driver's side), that by reversing the flow I might cause the passenger side to be the cooler one. I can tolerate that a little better since I mostly ride alone.
Any thoughts.
Old 01-15-2011, 12:12 PM
BlackBullet's Avatar
BlackBullet BlackBullet is offline
Vehicle: 2010 Ram Hemi TRX4
Trim Level: TRX4
Color: Brilliant Black Met
Rep:45
BlackBullet is on a distinguished road
there is that recall on the HVAC in our trucks. could that be the remedy?
Leveling kit, DSP tuner, 14" MAGNAFLOW with side exit, heavy duty DODGE slush mats, DODGE bed mat,BILLET TECH catch can, STAINLESS steel door sills, K@N drop in filter, level ride airbag suspension....
Old 01-22-2011, 09:56 AM
Any thoughts.
This sounds really interesting....it would also tend to backflush the heater core at the same time...........I really don't know if it would be good but I'd like to hear what others had to say about this.
Old 01-22-2011, 10:17 AM
Resident Technician
Rep:1915
The recall is for the defrost actuator (possibly others) and reflashing the HVAC controller. It only applies to the 2009 and some 2010 trucks.
Old 01-27-2011, 07:04 PM
Color: Gold/Silver
Well, I finally got around to swapping those hoses. Took all of 20 minutes. I believe its working just like I thought it would. I have nice toasty heat now on the driver's side and slightly cooler air on the passenger side. I'll post any negative effects I encounter here if they arise.
