Old 01-05-2011, 12:55 AM
magnusdeus24 magnusdeus24 is offline
Vehicle: 1997 Dodge Ram 1500
magnusdeus24 is on a distinguished road
Default 1500 7'' lift & 37''s help
So I am planning on getting a 7'' lift over the summer hopefully and I'm looking at the 37'' Nitto Mud Grapplers as my tire of choice. I am wondering:
a) because it is a bolt-on lift, would installing it myself be a good idea? I don't really have any experience with this stuff but I definitely want to learn as I go and have a few more experienced friends with tools willing to help.
b) with tires that big, should I upgrade my gears (I think I'm running the 3.55's, 1997 1500 4X4 5.2 V8) to either 3.92's or 4.10's? I will do some highway driving (maybe even a trip from Chicago to North Dakota where I go to school) and I don't tow anything, I'd just be lugging the 37''s around.
c) Has anyone else installed their own lift and can give me some pointers or have any pictures of the progress?
Also, any comments on this lift? yay or nay? (the 7'' slyjacker on the bottom)
http://www.jackit.com/dodge/pickups/...0_94-02.html#7
Thanks a ton in advance
97' 1500, Heartthrob exhaust, K&N short ram, black halo's, 33'' DC Mud Country, rancho suspension
Old 01-06-2011, 09:39 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Installing a big lift like that would be a pain without a lift in the garage. I'm pretty sure it could be done, but you would need some serious jeep-offroad hi lift jacks to do it. I would definately change the gears out with that much rubber and a smaller V-8. 4.10's would probably be a good choice. Ask around some more and get some more input!
Old 01-06-2011, 09:54 AM
Bodydoc2002's Avatar
Bodydoc2002 Bodydoc2002 is offline
Vehicle: 2009 Dodge Ram 1500
Rep:138
Bodydoc2002 will become famous soon enoughBodydoc2002 will become famous soon enough
I'm with Timmy i'd have it done...As for the rear gear I would switch to the 4.10 to pull 37's around...It takes a lot of pressure off of the Tranny with that larger gear and won't feel so doggy on take off....Which lift are you looking at? I just had the CST 7 inch lift put in 2 weeks ago....
2009 2WD Ram 1500. 7 inch CST Lift. 35 inch Mickey Thompson BAJA ATV. 20 inch ATX Artillery wheels. TOFF Spray in Bed liner. N-Fab 6 step Nerf Bars. BushWacker Pocket/Painted Fender Flairs. Diablosport Predator. K&N CAI 77 Series. 180 Thermostat. LED Tailgate lights.
Old 01-06-2011, 11:19 AM
volcom54626's Avatar
volcom54626 volcom54626 is offline
Vehicle: 2006 Dodge ram QC
Color: Brilliant Crystal Black
Rep:17
volcom54626 is on a distinguished road
At the very least you want 4.10 I would recemmond 4.56 with the 37" tires. That's wha im running and its perfect. As for installing the lift I think bolt on lifts are exactly that bolt on. With proper tools like mentioned a high lift jack, and you'll need a coil spring compress which you can get from checker or autozone(they rent them), and a level working surface and you should be fine. Just don't forget the alignment afterwards. That lift looks good though.
Old 01-06-2011, 06:48 PM
Thanks a lot for all of the input! I'll look at gears in the 4.10 and higher range and having it all professionally installed. One thing I just noticed though looking at the finer print of the lift is that it says the 1/2 ton is to the 2001 only? Is this lift still possible for me then
Old 01-06-2011, 10:04 PM
kejobe kejobe is offline
Vehicle: 2001 Ram 1500 4x4
kejobe is on a distinguished road
Yes. It's stating that the lift is for '94-01 1500 and '94-'02 2500. Dodge 2500 and 3500 2nd gen. went to 2002. The 1500 2nd gen. only went to 2001.
Old 01-07-2011, 12:32 PM
oh okay I thanks for clearing that up I was maybe thinking they were only referencing to like the 2001 sport package possibly as the only 1500 that it would work for
gears, installation, lift, suspension
