ALLGIG install / Ipod USB - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-05-2011, 05:19 AM
2011Ram's Avatar
2011Ram 2011Ram is offline
Vehicle: 2011 Ram Sport QC 4x4
Trim Level: Sport Premium
Rep:85
2011Ram will become famous soon enough
Default ALLGIG install / Ipod USB
I want to install the allgig and use the ipod port in the glove box on my 2011 Ram for a connector to the allgig/laptop computer. I will likely never use an ipod and it can probably just be plugged into the USB port on the front of my 430N (RHB) radio anyway. Ipod does not let you copy tunes to the HD anyways.
Is there any wiring diagrams that show where this glove box USB port is plugged into the radio? Can I just unplug it from the radio and plug it into the allgig?
This method would allow updates and reconfiguring the allgig without removing the radio because the allgig will be mounted behind it.
Old 01-06-2011, 10:47 PM
2011Ram's Avatar
Rep:85
Has anyone seen where the usb cable coming out of the glove box ends, and maybe what it looks like? Is it a regular usb end?
Old 01-06-2011, 11:08 PM
UN4GTBL's Avatar
UN4GTBL UN4GTBL is offline
Vehicle: 2007 Dodge Caliber
Rep:41
UN4GTBL is on a distinguished road
why not just plug a usb cable into the allgig, and then mount it in the glovebox near the ipod plug so you can access it easier? (good idea that you have here btw)
shouldn't cost very much
2007 Dodge Caliber SXT - 1.8L I4 & 5-Speed Manual
2011 Dodge Grand Caravan SXT Plus - 3.6L V6 & 6-Speed Auto
Wanting a new Ram...
Old 01-06-2011, 11:21 PM
Rep:2962
the connector ought to be in your upper glove box, if you have 2 of them
if not, members that have 2 glove boxes have pushed the sides of the lower box & gently pulled it out towards you, then look at the bottom of the upper box, there should be 1 screw, take that out & remove the upper box, the radio will be on the left & the wire comes out from the rear of it.
Some people have rerouted that cable to the little pocket that is located between the glove boxes & the climate controls, on mine that pocket is where the 115 AC plug is located. Others have routed it some other location, with use of a adapter extension that is available
Here is a good explanation & images, you can read the 2nd persons post if you don't need to access the radio face
http://www.ramforumz.com/showthread.php?t=65991
Good Luck
Old 01-06-2011, 11:29 PM
2011Ram's Avatar
Rep:85
That is a thought. Just wanted to make it look professional using the existing plugin that I have in there if possible. The existing plug is a standard USB in the glove box.
Old 01-19-2011, 07:06 AM
2011Ram's Avatar
Rep:85
here is a pic of where the allgig ended up, looking from driver's seat toward passenger side with console removed. You can see all of the additional audio/video plugs in the upper left coming out under the radio. The USB cable connected to the Allgig can de seen in the bottom corner of the allgig box. It comes out in the upper glove box. The factory backup camera has to be rewired to an accessory power in order to work while in forward motion, as it appears to get power from the backup lights. That could be a bit of a job to rewire, unless i come up with a close location to the tailgate to splice into.
Old 01-26-2011, 01:07 PM
2011Ram's Avatar
Rep:85
Factory backup camers does work.... see this link:
http://www.ramforumz.com/showthread....547#post424547
