tonneaucovered.com
Old 01-05-2011, 07:36 AM
donn12 donn12 is offline
Vehicle: 09 Ram
Trim Level: TRX
Rep:15
donn12 is on a distinguished road
Default pics of biggest tires available on stock 4x4?
I have a TRX4 4x4 and want to pass on a lift. I am not excited about a level because of all the problems I have read about but I think it may need a couple of inched in the front.
The only problem with the truck - the factory 275/70 17s wheels and tires are weak looking! I am open to new wheels if I need to get them but I will use this on the beach a lot so I want plenty of rubber (I don't want a low profile setup).
Who has put bigger rubber on a stock 4x4? I'm not looking for a monster truck set up at all. On a scale from 1-10 the truck size is a 10 and the tires seem to be an 7. How big can you go without rubbing and do you have pics you can share? I would love to see how big the tires can be with or without a level kit thanks!
Old 01-05-2011, 09:09 AM
Not having fit tires to your body style I'd have to hazard a guess.
A 285/70RX17 should fit without rubbing. Going taller, say to a 35, will be a squeeze and I suspect that they will rub under suspension compression. Any wider and they will rub on the inside without going to an after market wheel with a less positive offset wheel.
What has worked well for me in the past is to go to a local tire and wheel shop and have them mount up tires to your stock wheels and give them a try. Most are willing to do this at no charge.
We have a 2011 (or 4th generation section) but there's no need to post this there or in two sections. By the way, this got moved to Tires and Wheels where it belongs.
Old 01-07-2011, 07:43 AM
sensor5 sensor5 is offline
Vehicle: 2011 Dodge Ram QC 4x4
Color: Blue
Rep:13
sensor5 is on a distinguished road
I have 285/70/17 and they fit great with no rubbing.
Old 01-07-2011, 10:42 AM
09 TRX AGGIE 09 TRX AGGIE is offline
Vehicle: 2013 1500 Black Express 4x4
Rep:130
09 TRX AGGIE will become famous soon enough09 TRX AGGIE will become famous soon enough
i have 295/70 17 but on aftermarket wheels on a trx4. you can see in my sig.
on another forum, cough cough, i have seen a trx4 with "35's" and claim to have no issues.
Old 01-07-2011, 02:08 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
I have 305 55 Nitto Trail Grapplers i had to use a 1/4 inch spacer to keep from rubbing.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 01-07-2011, 02:32 PM
Vehicle: 09 Ram
Trim Level: TRX
Rep:15
Ram Tex no lift or level? Any pics?
