Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
View Poll Results: What weight oil do you use in your 5.7 engine
0W30 2 0.99%
0w40 1 0.49%
5W20 167 82.27%
5W30 19 9.36%
5W40 0 0%
10W30 7 3.45%
10W40 2 0.99%
15W40 1 0.49%
20W50 0 0%
Other 5 2.46%
Multiple Choice Poll. Voters: 203. You may not vote on this poll
Old 01-05-2011, 11:43 AM
Mcbride's Avatar
Mcbride Mcbride is offline
Vehicle: 2011 ram 1500 Crewcab 4x4
Trim Level: Sport/SLT
Rep:13
Mcbride is on a distinguished road
Default Poll on oil weight you use in your 5.7
I am curios about what weight oil everyone is using.
If you would please enter what weight of oil you use, or if choosing other, then please post the weight you use.
I tried to get enough options for most weights of oil, but there is always others out there for sure.
Its not a mistake that mans best friend cannot talk.
Old 01-05-2011, 11:48 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Use what is called for, 5w-20 or you might see problems. There is a thread somewhere about it. It messes with the MDS...
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 01-05-2011, 12:02 PM
I push the skinny pedal
Rep:3277
Yes, since the MDS is oil pressure activated a change in weight can affect the MDS performance, or in some cases puts stress on the oil pump due to it having to work harder/spin faster due to a heavier/lighter oil respectively.
Kurtis
Old 01-05-2011, 12:13 PM
Rep:1885
Incorrect oil viscosity can set a code in the PCM and turn on the MIL.
Old 05-29-2011, 11:58 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
5W20 or 0W20, that's all you should be using in an MDS engine period ......
Old 05-29-2011, 12:59 PM
5W20 is used in mine.
Old 05-29-2011, 02:30 PM
Mcbride's Avatar
Rep:13
I just want to add that mine runs perfectly on 5w30.
Its only going to be a little thicker once the oil is very hot, but at start up and moderate temps is the same viscosity as 5w20 is.
Old 05-29-2011, 03:52 PM
Ben616 Ben616 is offline
Vehicle: 2011 dodge Ram ST
Trim Level: standard
Color: mineral Gray
Rep:20
Ben616 is on a distinguished road
I had a question on this issue in anouther thread I use Ultramar synthetic 0w30 in all my 4 cycle engines gas and deisel and wanted to know if it could be used in a hemi.
Old 05-29-2011, 06:45 PM
Terrence's Avatar
Terrence Terrence is offline
Vehicle: 2013 Dodge Ram 1500 RCSB
Rep:57
Terrence will become famous soon enough
i run 5w 20 cause thats what gets used at the dealership when I get it changed there.
Old 05-29-2011, 08:54 PM
rickerred's Avatar
rickerred rickerred is offline
Vehicle: 2011 Sport
Rep:43
rickerred is on a distinguished road
When you see a W on a viscosity rating it means that this oil viscosity has been tested at a Colder temperature. (SAE oil is tested differently) 5w is the weight at cold, 10,20,30 ect is the weight at operating temps (not very hot). So 5w20 and 5w30 are not the same thickness at operating temps 20 will be thinner.
Mods: Garmin GPS, Trifold Tonneau Cover, Molded Mud Flaps, K&N Cold Air, Westin Oval Step Sides, Vent Visors.
Future Mods: What ever I can sneak by my wife.
