Old 01-05-2011, 10:48 PM
Taggert Taggert is offline
Vehicle: 2008 Quad Cab
Rep:30
Taggert is on a distinguished road
Question Stock Muffler Leaking Water
2008 Ram 39000 miles, stock exhaust. I happened to notice water leaking from the back of the muffler today. On closer exam, the seams are rusted. South Carolina is not that harsh of a climate. Is this a problem?
I want to change to Mag muffler, don't want to be too loud. What is the difference between 14" and 18" as far as sound?
Old 01-06-2011, 03:05 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
The outside of the muffler and the seams will rust naturally, but take a look at the back of the muffler toward the bottom, there should be a small hole drilled in it. It is designed to weep moisture that leads to rust on the inside of the muffler. This may be your leak.
As for 14" vs 18"... depends on your taste. To get a good comparison you might try to find some sound clips on YouTube.com. Just input the muffler brand and the size, you should get some decent clips. A buddy of mine has the 18" Magnaflow, I have a 24", both single-out exhaust systems. The 18" seems plenty loud.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 01-07-2011, 11:44 PM
Rep:30
Thanks for the info! Had to take a quick trip out of town. Just checking back in. You are spot on. The water is coming from right where you indicated. I'll check YouTube for the comparisons.
Old 01-07-2011, 11:47 PM
^^agreed^^
Old 01-08-2011, 12:03 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
its a good thing
Old 01-08-2011, 12:25 AM
Rep:2620
the water is coming directly from your catalytic converter, it suppose to happen
the contaminants from your engine that produce smog & other pollution, goes into the converter(s), the so called tiles in there are coated with a substance, the N0X then cling to that substance & are converted to plain water & then come out of your exhaust
Old 01-08-2011, 07:02 AM
HVACeR HVACeR is offline
Color: Mango Tango
Rep:113
HVACeR will become famous soon enoughHVACeR will become famous soon enough
Water not only is a natural by product of combustion but their is water (humidity) in the air that is pulled into your engine through your intake and the expelled through your exhaust.
MODS: BellTech 2/4, Air Lift 1000 Air Bags, Mufflex DOD14M, Partial Debadge, Pin stripe removal, B Pillar blackout removal.
