Old 01-05-2011, 11:51 PM
Chad2011 Chad2011 is offline
Vehicle: 2011 Ram 1500
Chad2011 is on a distinguished road
Default Towing with 17" vs 20"
Was just curious why I hear of 1500 Ram owners using the 17" rims and tires instead of 20" rims and tires. Is it because the 10 ply tires are too big on the 20" and will rub? How is towing recreation boats less than 4000 lb with the 20" tires?
Old 01-06-2011, 01:23 AM
It's because 10 ply or E rated tires are hard to find in a 20" size and the sidewall has to be so tall that they don't fit.
I haven't tried towing a small boat with 20's on this rig but I did with another one with 20's and had no problem.
Old 02-01-2011, 03:58 AM
Nematocys's Avatar
Nematocys Nematocys is offline
Vehicle: 2009 Ram 1500 4x4 5.7L Hemi
Trim Level: SLT w/dealerupgrades
Color: Sunburst Orange
Nematocys is on a distinguished road
Motor Trend had an interesting article about the 2009 with a blurb on the towing issue being discussed. Here is a link to the article:
http://www.motortrend.com/roadtests/...ion_specs.html
Notice the double astrix in the chart.
Thought....opinions????
Old 02-01-2011, 09:45 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
You do realize these are not "10" ply tires correct? I see this all the time and hear tire store tell people about 10 ply tires....there is no such thing as a "10" ply passenger car or light truck tire. This is an old term from the days of bias ply tires..with today's radial tires they are mostly 2 ply, with some 3 ply exceptions. So just understand that "10" ply is NOT 10 ply..it is just an old rating used from the days of bias ply tires. Unfortunately tire store salesman throw the term around and confuse many consumers.
MADDOG is dead on about "E" rated. That is about the highest rating you can get in a Light truck radial tire..they are found stock on 2500 and 3500 trucks.
I tow a 6,500lb trailer with no issues with 20's...I can't imagine you will have any problems at all.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 02-05-2011, 03:50 PM
miketen07's Avatar
miketen07 miketen07 is offline
Vehicle: 2010 Dodge Ram quad cab 2wd
Trim Level: big horn
miketen07 is on a distinguished road
Just to let you guys know i used to have a set of 275/55/22 on a ford f150 the were e rated i held around 2500lbs in the bed and sometimes i used to tow around 12k lbs the tires were pirelli scorpion str the tire held up great but the brakes and suspension needed modding
Old 02-05-2011, 05:46 PM
kgb503 kgb503 is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Trim Level: Sport 4x4 3.92
Rep:52
kgb503 will become famous soon enough
OK, now I'm confused. I took a look at the article you linked to and did see the double asterisks, specifically the comment that you would have to deduct 1100-1150 lbs for 20" wheels, off of max towing.
What is confusing me, is that a while back I came across a post that had a link to a very handy pdf (rammlup1500.pdf) titled "2010 Ram Base Weights/GCW/Payload/Trailer Tow 1500" - sorry I didn't find / provide the link or original post as a reference.
But in that pdf, I looked for my truck specifics to see what my towing limitations are, and for a Crew Cab 1500 4x4 SLT (they didn't list Sport - just ST, SLT, and Laramie) they listed several different combinations (tires, engine, gears).
And what they had listed for mine, P275/60R20, Hemi, and 3.92 gears, was a max trailer of 9900 lbs, and payload of 1380 lbs (and a base weight of 5393).
By comparison, for the same vehicle, but with P265/70R17, there was only a 50 and 40 lb difference...9950 / 1420 (and a base weight of 5351).
They also had another tire option, LT275/70R17C - which had the same numbers as myine with 20's...
So I'm wondering what numbers I should be using when looking to stay under for towing safely? The 9900 - or 1100 off of that?
And if the wheel size effects your max towing, would it also lower the payload capacity?
I only ask because I'm looking to buy a new RV (possibly a short & lightweight 5th wheel), and I am using these numbers to narrow my search options...
Thanks!
Old 02-07-2011, 05:48 AM
Nematocys's Avatar
A quick google search found that PDF you were referring to (http://www.dodge.com/bodybuilder/201...ammlup1500.pdf).
After reading it and looking a the specs....I would put more faith in what the PDF says vs. what the article I posted states.
Just FYI...
I have a 2009 Hemi 5.7L 4x4 SLT w/17"ers and I tow a Coachman Catalina 34' with no problem at all. Here are the weight specs on my camper:
WEIGHTS
Base Weight 6,512 lbs.
Carrying Capacity 2,988 lbs.
GVWR 9,500 lbs.
Hitch Weight 810 lbs.
Old 03-02-2011, 11:28 PM
Zeus Zeus is offline
Vehicle: 2011 Ram 2500
Color: Rugged Brown
Rep:27
Zeus is on a distinguished road
I have the 20's wrapped in 35" Pro Comps and pull a 24' Cuddy cabin boat with a 454 in the back with no problems. I just dont let it click over into 5th gear to help the tranny out
Old 03-03-2011, 01:12 AM
viper19JN's Avatar
viper19JN viper19JN is offline
Vehicle: 2009 ram 1500 quad cab
Color: mineral gray
Rep:30
viper19JN is on a distinguished road
Just FYI...
WEIGHTS
GVWR 9,500 lbs.
Holly crap man my grand parents have a 30' just like yours and I wouldn't dream of putting it behind my truck even with the load level hitch lol good to know its possible I bet you get no mileage though
Old 03-06-2011, 04:20 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
This website is advertising BFG All Terrain T/A KO in a 10 ply if that is what you are looking for.
https://www.tiresavings.com/tireShop...season=Regular
