Old 01-05-2011, 11:52 PM
tpollon2 tpollon2 is offline
tpollon2 is on a distinguished road
Default 2010 Dash Speakers Alpine system
Has anyone had their dash apart? Would like to know if anyone has up-graded their dash speakers? Are there 3 up there (one in the middle)? How difficult it is to replace them (does the entire dash have to come off)? I know they are 3-1/2".
thanks in advance
Old 01-06-2011, 03:12 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
There was a thread started to help members with audio related questions. You might try searching for an answer to your question there, or asking it there in order to get a quicker answer. I haven't gotten that far into my audio upgrades to tell you myself. Good luck!
The audio thread is located here: http://www.ramforumz.com/showthread.php?t=60713
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 01-08-2011, 09:42 PM
loansinpa loansinpa is offline
Vehicle: 2009 Ram Sport 4x4
loansinpa is on a distinguished road
They actually come out pretty easy...assuming you're gumby. The plastic covers just pop off with a small blade screwdriver and then it's just manipulating a screwdriver to get the speakers out. Problem might be finding a quality 3.5" I don't think it's a real common size.
Old 01-08-2011, 09:48 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Like mentioned ^^^, easy to get to, but using an offset screwdriver to get them out would be best. There are tons of options for replacement, depending on what direction you are heading (amps, new headunit, active, passive, simple replacement)
Old 01-08-2011, 09:50 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Sad part is they are 7mm (I think) on the 2010. Be real careful when manipulating the socket wrench, you don't want to whiz that thing around and put a nice crack in the windshield.
Old 01-09-2011, 01:18 PM
hpc3 hpc3 is offline
Vehicle: 2010 Ram 1500 Laramie Crew 4x4
Color: Inferno on Slate
Rep:44
hpc3 is on a distinguished road
Send a message via AIM to hpc3
Default I'm running the 3.5" Infiniti Kappa 2ohms in mine...
They fit and sound *much* better than the stockers. I originally wanted to replace the center dash and two headliner tweeters but have left them alone due to odd sizing. Just replacing the outboard dash tweeters makes a huge improvement. I also tried using Kappa 692s to the front door locations(like in my 3rd Gen) but these doors have a plastic regulator carrier subassy unlike the steel doors in the older truck so I chose not to cut them in order for the speaker to sit deep enough.
The little 2-way 3.5s though make a big difference for ~$90/pair. Not muddy like the stockers and they bolt right in.
2010 Ram Laramie Crew 4x4, Inferno(mono) on Slate, All options, including BigSloshiTank
Old 01-09-2011, 01:23 PM
There are some nice 3.5's out there. A 4" will also fit with some modification to the opening and a simple mounting bracket.
Getting to the screws/hex heads can be a pain. I just use a mini socket and ratchet, being careful to not smack the windshield!!!
