Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-06-2011, 10:35 AM
grungybob grungybob is offline
Vehicle: 1999 dodge ram 1500 4wd
Trim Level: sport
Color: red
grungybob is on a distinguished road
Default heater stopped suddenly
I have a 99 1500 4wd ext cab 5.2l the heater suddenly stopped, the engine temp is at normal operating range so i dont think its a coolant issue it seems to be a control issue. The dial control for the mode setting operates, it just has no effect and the fan speed knob operates with the same lack of doing anything. Anyone seen this or have any tips
Old 01-06-2011, 11:56 AM
Rep:1890
The blower is dead and the modes won't change?
Old 01-06-2011, 01:26 PM
Trim Level: sport
Color: red
Yes all of a sudden nothing works, the back lighting for the controls is there but the switches/knobs do nothing. Like somebody pulled the plug
Old 01-06-2011, 01:32 PM
Rep:1890
Check and see if there is power at fuses 2 and 5 in the fuse panel with the key in the on position. if not, you may have an ignition switch/wiring problem in the column. Both the blower motor and blend door are fed from this circuit.
Old 01-06-2011, 01:38 PM
Trim Level: sport
Color: red
I'll check it later, Thanks I'll let you know
Old 02-13-2011, 10:42 AM
rlsbee rlsbee is offline
Vehicle: 1998 Dodge Ram
Trim Level: Laramie SLT
Color: Red/Silver
Rep:26
rlsbee is on a distinguished road
Check the relay for the blower motor. It's in the the PDC under the hood. The part is really cheap and it's worth changing it before chasing a lot of stuff. If yours is like my '98 there is a relay for one of the other functions (sorry, I don't remember which one) which is the same part number as the blower relay. Swap it into the blower socket and check the blower.
