Old 01-06-2011, 11:03 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Default Trick Flow Harmonic Damper
Anyone know specifically what the benifits are from this product? Im assuming that it is just smaller than stock? Basically freeing up horsepower?
http://www.trickflow.com/egnsearch.a...0&autoview=sku
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 01-06-2011, 11:54 AM
Rep:1885
Depending on how well your engine is balanced, it may make it run a bit smoother and if it's lighter it could allow the engine to rev a bit faster.
Old 01-06-2011, 12:37 PM
RamTex's Avatar
Color: Stone White
Rep:366
Oh i see i just read the pdf on there site it underdrives the accesories such as condensor and alternator by 20% making less rotational drag to let the engine rev faster.
Old 01-06-2011, 03:10 PM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
That's right, the smaller pulley turns the belt slower so there is less parasitic drag on the system. If you are worried about your alternator not putting out enough, you can get a alternator pulley that's 20% smaller as well to keep it turning at the stock RPM.
Kurtis
Old 01-06-2011, 03:22 PM
RamTex's Avatar
Color: Stone White
Rep:366
I think if ill get this when i get my cam + the alternator pulley.
Old 01-06-2011, 06:34 PM
NashvilleHemi's Avatar
NashvilleHemi NashvilleHemi is offline
Vehicle: 2004 Dodge Ram
Color: Dark Molten Red
Rep:24
NashvilleHemi is on a distinguished road
I have one!! you will definatly feel it.. i left 50ft of rubber on the driveway last summer, could'nt do that any other time!!!
Dynomax cat-back, K&N CAI 77series, AFE TB spacer, Trick Flow 20% underdrive balencer, MSD 8.5 wires, e3 plugs, 3865 Super Chips, Fastmans ported TB, 180 T-Stat
Old 01-06-2011, 09:08 PM
ThunderedRod's Avatar
ThunderedRod ThunderedRod is offline
Vehicle: 2006 Dodge Ram
Rep:17
ThunderedRod is on a distinguished road
interesting, did you throw any codes?? and what about a smaller belt? or does the belt tensioner solve that problem?
K&N CIA, CORTEX, TTI HEADERS AND Y-PIPE, MAGNAFLOW CATS, FLOWMASTER SUPER 44, and more . .
Old 01-06-2011, 09:15 PM
Good find .
Old 01-06-2011, 09:51 PM
TheSatinPumpkin's Avatar
Color: Satin Orange
Rep:605
Old 01-06-2011, 10:46 PM
Rep:24
No codes!! i just did a 2000 mile trip from Nashville to NY and back with no codes or problems.. You do need a smaller belt.. part #4060990..
